Question about Dewalt 18 Volt Compact Drill Kit
While unscrewing a lugnut the entire chuck came unscrewed. Now when I try to unscrew anything with power the chuck comes unscrewed. How do I fix it?
  • 557 Answers
Put a drop of locktite on the threads reinstall and let cure.
Posted on Sep 25, 2009
  • 30 Answers
Try this. Open chuck as wide as possible using a flashlight look in to see if there is a screw in there. What usually happens is the screw broke or came out from to much torque. It holds that area of the drill together. If u see the screw broke off you will have a hard time fixing it. if it came out u need to find the screw or a replacement one.
Cordless drill chuck problems jammed closed
Jam the chuck in a vice and the with help of w40 oil try to unscrew open
Dec 28, 2017 | Drills
How do you remove the chuck on a cordless drill?
If it is a reversible drill open the chuck as wide as possible.
Look inside for a screw that prevents the chuck from coming unscrewed. Remove the screw and you shovld be able to unscrew the chuck.
Aug 25, 2014 | Drills
How do I change the chuck in my Craftman 3.5 electric drill
If you open the chuck as far as it will go and look inside you may see the head of a screw, especially if the drill is reversible. So undo the screw and then you should be able to unscrew the chuck. But I am not sure if it will be easy to unscrew. With a keyed chuck you use the key and a hammer to unscrew the chuck.
Oct 14, 2013 | Drills
A dewalt dcd970 18v xrp and when i try to unscrew anything the bit comes loose. Can't figure out why?
check the inside of the chuck at the bottom(open the chuck to max). There should be small screw there with either a hex or a Phillips head. It is a left hand screw that locks the chuck in place and will not let it unscrew when you are removing parts.. If it is not there then you will have to get one from an old drill that is junk unless you can get one from an electrical appliance shop the repairs drills.
Oct 24, 2011 | Dewalt Air Tools & Compressors
I HAVE A DEWALT 511 HAMMER DRILL AND I CAN'T REMOVE THE CHUCK. COULD PLEASE ADVISE ME ON WHAT TO DO.
Open the chuck fully and look inside, there should be a screw there that has to be removed to remove the chuck in view of the fact that it is a reversable drill and the chuck cannot be screwed off like a conventional inudirectional drill.
Jul 09, 2011 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
Want to Replace chuck Keyless chuck always loosens and bits fall out.
Inside the chuck barrel there is a screw which unscrews counter clockwise, then
the chuck itself should unscrew counter clockwise as well.
May 09, 2011 | Ryobi 18volt 12" Cordless Drill Model P206
How do i remove the chuck- usually its got fixing screw in the centre,but this model doesnt, does the chuck just unscrew from the shaft if i hold the shaft?
yes usually you have to put a allen wrench in the jaws of the chuck tighten it and hit it with a hammer to unscrew it.
Mar 17, 2011 | Garden
On a model 315.101231 3/8 corded drill I need to remove the keyless chuck how do I do that?
May 31, 2010 | Craftsman 3/8" Corded Drill
The chuck came unscrewed from the spindle assembly
yes it can, what you need to do is lock the chuck as tight as you can and then replace the chuck retaining screw which you should be able to find locally, it is a left hand thread.
Apr 20, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
DeWalt 12V cordless the chuck mow backs out under load
That depends take the chuck off and see if you can see a part of a screw in the spindle. If so try and turning it with a small pick to remove it. It sounds like all you possibly broke was the chuck retaining screw. You can go to a repair center and pick one up relatively cheap or go to Dewaltservicenet.com and type in your model number to look at a breakdown for this part. Let me know if anything different, I take it also that the tool runs and sounds OK otherwise?
Jan 22, 2009 | Dewalt Drills
Dewalt 18 Volt Compact Drill Kit Logo
74 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
