Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
The vegetable department and the deep side of the shelf - food become frozen ??
  • 403 Answers
I do not know what brand and model you have but there are several controls that you may need to look at. Some of these shelf's have a control lever to adjust air flow. Check your two control knobs at the top and set them to initial settings. Hope this helps. Let me know if I can help you with anything else.
JimmyC
Posted on Sep 25, 2009
Why Select a Vacuum Food Sealer?
You may have heard a lot about food sealers but you may not know them very well. Food sealer can provide you with an easy way to seal your food by removing air from the packages so that they will not get bad when you want to eat it. We all have experienced that we put food in the refrigerators and plan to eat it later, but later never comes. It's really a huge waste not only of food, but also of money. The food sealers work to prevent that waste by keeping your food fresh.
With a food sealer, you can buy fresh food as well as vegetables and take them home. Food sealers make it possible for you to buy food in bulk since you can seal and freeze it to avoid waste. It will remain fresh after a long time compared with the unsealed one. By removing air from the packages, you can take all of the air out of the packages. If you have air in them or put them in the refrigerators, you will allow germs to get into your food, which will make it become unsafe. If you do not eat it within a "safe time" and it's not well protected from the air in your fridges, you will have various odors from other food inside your fridges that can mess up the flavor. Your food may become discolored. This is because the freezers' pulling moisture out of the meat and vegetables due to your container allowing air into your food. Your frozen food will dry in the end. Although it's still safe to eat, it won't taste as good as it originally is. Food sealers are systems that seal food in air-tight vacuum packed systems like pouches and used for foods that need to be stored for long periods of time.
Anyway, food sealers can help reduce oxygen, limiting bacterial growth that would otherwise cause vegetables, meats and liquids to spoil. Sealing food guards against dehydration and freezer burn, and also saves on storage space because of the reduced size of the packaging. As an added perk, you can use the vacuum sealer to marinate meat or combine foods for ready-made meals. http://www.vacuumsealermanufacturer.com/
Aug 14, 2017 | Select Kitchen Appliances - Others
My freezer only freezes certain food. All the
Get a freezer thermometer and ensure the temp is turned down to between 0 and 10 degrees F.
Oct 05, 2014 | Refrigerators
My GE Refrigerator doesn't work properly.
The two main causes for your problem is the control set wrong and the second one isthe defrost element has burned out... Sometime the defrost clock will go out as well.... always try to set your controls to midrange and if the bottom of the freezer compartment is cold and frosty but the refrigerator is cold ... Remove all the food and store in a backup refrigerator you can rent from an appliance rental center... Unplug your refrigerator and let it defrost for 48 hours.... In the mean time open up the doors and clean it from top to bottom. place a fresh opened box of arm and hammer baking soda in the frige side and one in the freezer side. Plug back in after completely deftosted and place a small plastic cup half filled with water on each shelf of the freezer. Close the doors and wait 8 hours... Open the freezer and check the plastic cups.... if they are all frozen great..now wait for 3 days do the test again if the bottom cup is frozen and the top shelf is not ... its time for a new defrost element or a defrost timer.
25 years service
stocktongoodrepair@gmail.com
Sep 21, 2014 | GE Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
My vegetables & meat shelves are frozen
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
May 01, 2011 | Kenmore Side by Side Refrigerator
Ktake out glass shelf over vegetable bin
The glass shelf usually just lifts up and out after you remove the bin. Sometimes food has spilled and "glued" it to the rack. A little hot water applied around the edges should melt the food glue.
Jan 16, 2011 | Kenmore Refrigerators
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
The temperator is uneven
Our side by side GE model # GSS25SGPESS is not cold on the food side. the temp in the refrigerator is 48 degrees.
Apr 18, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Frigidaire FRS26r4cw3. frozen on the vegetable section
the coldcontrol check to see if your doors closing it may be (ajar)
Jan 05, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
