My acoustic soloutions 14 inch CRT with text TV has green colour at the top of the TV screen and a purple colour at the bottom of the TV screen, these odd colours change the colour of the things and people on the TV, the purple at the top turns the top of peoples heads green and the green at the bottom turns their hand blue etc. This started a few days ago and covers altogether two thrids of by TV screen, could you please tell me what the problem is?
HELLO
I think what you have here is a degaussing problem causing purity errors on colours. When you switch your TV on there is a coil around the rear of the tube which is connected to a posistor and this is to get rid of any residual magnetism.
It sounds like the circuit is not working correctly possibly caused by a faulty posistor. Another reason could be that you may be using the set by putting it in standby all the time - the degauss does not work as it should by doing this - the best way is to switch it off properly after use and on again by the switch on the TV itself.
If the problem does not go away, then you'll have to get a service engineer to sort it.
I wish you well with your problem (:-)
Try to disgusting it and next time don't near it the magnet or speaker
Was the tv dropped?--try manual de-gaussing.If that does not
work,the problem may be the shadow mask inside CRT or the
yoke is loose and mis-adjusted on the neck of CRT.
