I have a Seagate Barracuda 7200.11 hard drive that quit working. When we turned the computer on it said: Boot disk failure. Please insert system disk and press enter. At some point I got to the diagnostic screen where it performs a check of the computer. It came back saying there was an error with the boot path. Error code was BIOHD-2, no drives detected. How can I fix this without loosing my data?
    Problem Solver:
  • 7 Answers
Hi Levi08. By now you probably already have 1) resolved or 2) tossed the offending Seagate, but maybe this will help others out there with 500GB - 1.5TB Barracuda 7200.11 drives that may be experiencing this problem now.
Check out this Seagate forum: http://stx.lithium.com/t5/ATA-and-Serial-ATA-drives/Barracuda-7002-11-not-detected-in-Bios-or-Windows/m-p/45355
CNET discusses the firmware issue in more detail here: http://news.cnet.com/seagate-fixes-7200.11-drives-except-when-it-doesnt/
In a nutshell, most failures where the 7200.11 can't even be read by the BIOS suddenly is a flaw in the original firmware. Because of the range of HDDs this affects, Seagate has allows end-users to have access to the firmware and it is reported that Seagate will perform data recover of any drives that crashed with the faulty firmware.
The Chief Geek
www.TheChiefGeek.Org
Posted on Apr 28, 2010
  • 3 Answers
Get an original cd of your operating system, then use it to repair the windows. I think this will solve ur problem.
Posted on Sep 25, 2009
    Scholar:
  • 131 Answers
Not sure what operating system you are using. If it is an actual hardware problem you will find it extremely hard to recover these files. If the system still recognizes the hard drive? you may be ok. Insert the Windows disk and boot from it. The system will boot, you will see "Windows Setup" then you will notice it loading files. Be patient here. When you get to the screen that says at the top "Windows Setup" choose r for recovery console. Then it will examine your disk configuration. When that is complete it will ask you to logon, then you will see the command prompt. Type this: fixmbr then once this is complete, try rebooting your computer and voila (hopefully)
Hope this helps
When I boot my pc I get an error (Disk Boot Failure Insert System Disk)
You will have to get a bootalbe disk of Windows to repair the Windows installation.
Aug 08, 2010 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Segate portable hard drive 500 gb not able access
is the computer see ing it if not ,unplug run computer then turn off re plug in and computer should see it with its plug and play system
Jul 06, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Disk Boot Failure
You can recover the data by connecting this drive to another system or if you have windows operating system just install it choose the repair option. But first you connect this drive to another system as secondary drive and take the backup.
Have a nice day and do not forget to rate please...!
Feb 08, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hard disk very slow and restart.
Seagate is known for hard drive failures. The S.M.A.R.T. feature may warn you that the drive is failing. This is not uncommon and is most likely the case of why it is going slow now. You should contact seagate ASAP to see if they can give you a replacement.
Jan 31, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
More than likely, since you say you did a DOS install of the OS, you did not set the FDISK parameters to set your primary drive. Insert the DOS CD you used to format the system. Boot to a DOS prompt and run the FDISK command. It should have an option, I believe it is number 2 or 3 to "Set primary drive". Select your hard disk 0 as this drive and you should be fine at rhat point.
Disk not being Recognised: Windows XP asking for driver
s cuase u r using ur hard disk with different mother board so u need to format it or u need to get teh mother board cd an dchange the boot sequence as cd-rom and run it
Oct 31, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Hard disk failure
Go to www.gillware.com They can get files off damaged hard drives. If they can't recover your data, you don't pay anything. When you fill the form out, check "I was referred by an affiliate." And enter code 10869.
Aug 08, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Computers & Internet Logo
788 people viewed this question
David Payne
David Payne
