Question about Kodak ESP 5 Printer
Access door open - Kodak ESP 5 Printer
  • HARSH BAWA May 11, 2010
    Kindly clarify whether the access door is not opening or it is not closing or it has gone bad ? Or you getting any kind of "error message "
  • 295 Answers
Kindly close the access door then.If you are getting the message even after closing the access door,its time to call kodak at 1800 421 6699 and the printer will be replaced free of cost for you.Access door is the door that is opened to change the cartridges.
Posted on Oct 10, 2009
I have an open door message on my hp 350 copier printer
Open the door, ensure there is no debris of any kind arount it and then shut it firmly. This may resolve the issue
Jun 10, 2015 | HP Deskjet 350 InkJet Printer
Error code 3806
From Kodak support:
Open the printer access door.
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer.
Turn the printer on if necessary.
After the printer has powered up, the message "Printer access door open" will appear.
Close the printer access door.
Remove and install the printhead two times.
Wait until the printer is ready to use.
Jun 07, 2012 | Kodak   ESP5250 Es Printer
How to access door to ink cartridges
This video explains how to open the access door to replace ink cartridges.
I am an HP employee.
Mar 17, 2012 | HEWLETT-PACKARD Officejet 4500 All-in-One...
Carriage jam
Hi
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Feb 27, 2012 | HP C6250 InkJet Printer
Ink door open meassage
Open cartridge access door, observe left side door switch located, manually operate it feel weather its working or not, close door & check.. not rectified, insert peace of paper in it. check...
Feb 02, 2012 | HP Photosmart C6180 All-In-One InkJet...
Code 3514 keeps coming one
Error: "Rear access door open" (3514)
How do I resolve the error message "Rear access door open" (error code 3514)
To clear the "Rear access door open" error message:
  1. Remove the rear access door from the printer.
  2. Reinstall the rear access door on the printer and verify that both latches are securely engaged.
  3. Unplug the AC adapter from the printer.
  4. Plug the AC adapter back into the printer.
  5. Wait for the printer to initialize.
  6. Verify that the error has cleared.
Mar 18, 2011 | Kodak Office Equipment & Supplies
Door will not open, but the display indicates that the door is open
There is an emergency access cord that can be used to unlock the door when the door lock mechanism fails to unlock it after a wash load is done. The cord is located under the top cover and can be accessed through the dispenser bezel. Disconnect power to the machine before accessing the cord.
Open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off to access the emergency access cord. Pull the emergency access cord carefully and steadily then open the door.
Aug 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Printer shows error code 3802 printer will not print
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  5. Close the printer access door.
If the error continues:
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error continues, contact Kodak.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a paper jamb. Page 45 of the manual says to open the rear access area and pull out the paper. There are no drawings showing how to access this area. How do I open the rear access area?
Gently press and hold the tab on the left side of the rear access door assembly. Carefully pivot the left side of the rear access door assembly toward you to remove it.
Note: Before you remove the rear access door make sure to remember the original position of the rear access door., base on my experience its really hard to reinsert the rear access door. GudlucK
Nov 03, 2009 | Kodak ESP 5 Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP 5 Printer Logo
563 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
