Question about Sport & Outdoor - Others
1995 EZ Go Electric Golf Cart is inoperable; batteries are fully charged
  • 6 more comments
  • rablf Sep 25, 2009
    Total voltage = 37.2 and does not drop when pedal is depressed. A loud click can be heard and felt from an enclosed component behind passenger seat. Will not move forward or backward. Reverse warning signal is working.
    Never got a response after I checked the things I was asked to check.
    It will not move forward or backward. Total voltage is 32.7 vdc. A loud click can be heard and felt from an enclosed component behind the passenger seat. Reverse warning signal is working. Total voltage does not drop when pedal is depressed.
    FLASH!!!! While checking voltage to motor (with pedal depressed) the cart suddenly moved forward. I was also testing what I assumed to be relays, x2, located on what I call "rotary" switch. Cart now operates intermittantly. What now?
    I was checking voltage at terminals and continuity across relays? using a Honeywell multi-meter. Now -cart will operate but ony at full speed.
    No response at partial depression. Cart operates at full pedal
    How can I identify the electronic speed controller? Is this the part name to ask for to obtain a replacement?
    Thank you very much for your time and effort.
  • 15,935 Answers
Check the wiring for looseness, and also the ground wire (s) for corrosion.
The speed controller (if electric) may have failed.
Were the batteries replaced at any time, and re-wired incorrectly?
Does the voltage drop considerably when you try to move the cart?
Because the batteries are "charged" does not mean there is enough supply voltage for the motor to spin.
Any unusual noises or smells when trying to move the cart?
Any additional information can be helpful. Troubleshooting eletcical circuits is difficult remotely. You have to be My eyes and ears (and nose) :D
Thanks for using FiYa!!
Posted on Sep 25, 2009
  • 1 more comment
  • blueextc3221
    blueextc3221 Sep 25, 2009
    Some additional comments....
    Check the run/tow switch is fully engaged - and also continuity and proper operation of the Forward/reverse switch.
    Finally - CLICK HERE for good motor tests to verify the motor is good.
  • blueextc3221
    Sorry for the delay - email is dragging today.
    As my first response indicated - and your subsequent findings back up - the electronic speed controller is faulty. Upon disassembly, you may find diodes burned, or other parts visibly charred.
    You still may accept this answer or continue asking questions that I will answer as soon as I get notification you have left a reply.
    Thanks!!
  • blueextc3221
    The speed controller will be under the front seat in most applications.
    It will look similar to this....
    or this...
    Depending on the amperage rating.
    You'll need the part number from it to match it to a replacement - as depending on the options installed - it can vary significantly.
    CLICK HERE for a good source also HERE
    Thanks for using FixYa - choose accept on this answer to remove it from the work queue if there are no additional concerns.
    President:
  • 2,777 Answers
What do you mean when you say inoperable? Does it turn on at all when you turn the key? You are sure the battery works fine, or can test it and it's charged for sure? If so, do you at least get any light indicator anywhere, what about when you put it in reverse? If nothing indicates any power at all then something is probably wrong in the wiring / the starter has failed.
Hard to say, please let me know more here and I will definitely help you out.
Thanks
Tim
  • Tim Grayson
    Tim Grayson Sep 25, 2009
    So while you were TESTING it it moved? Was it the second you put the tester to the terminals? If so... what kind of tester are you using? Maybe it gave it a tiny boost..
    Let me know
    Thanks
    Tim
  • Tim Grayson
    Wow, something strange going on, now it's working at full speed only? So there is no slow you mean?
    Tim
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
I have a 1995 ez go electric golf cart.when it is fully charged i drive it and i start losing power.then i put it back on the charger it is only one third charged.I checked my batteries with a metor and...
if you didnt check the amperage the battery is going bad it may read 12 volt or 36 volt depending on the wiring but if it will only charge a 3rd of the way then the battery needs to be replaced because the amperage is not there to completely charge so it will lose power do to lack of voltage/amperage.
I hope this helps
Sep 02, 2011 | BMW 318 Cars & Trucks
I HAVE A 1999 ez go cart and we smelled burning
Look under the cart and make sure the wires to the motor are good.
Oct 01, 2009 | 1995 Volkswagen Golf
Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Jul 17, 2009 | 1995 Volkswagen Golf
NO CHARGE GETTING TO BATTERIES
If your batteries aren't holding a charge then they might need to be replaced. When batteries are used seasonally their life span is generally shorter. You can check them using a voltmeter. If you need a replacement you can check out www.batteryinternational.com or call 1-877-28-BATTERY if you are having difficulty finding the battery you need.
Jan 14, 2009 | 1995 Volkswagen Golf
1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
Jan 05, 2009 | 1995 Volkswagen Golf
Sport & Outdoor - Others Logo
152 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
