Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Grit on dishes
When I turn on the dishwaser I notice that the are at the top is not turning. and there is a grit on my dishes. does anybody have a solution
  • Frigidaire Master
  • 909 Answers
Remove the top rotor and start a wash . when running, briefly open door and see if water is pumping out of hole where rotor was connected. If it is, your rotor is badly blocked.(clean properly) If not,a valve that should be opened is not.From there you will need professional attention.
Posted on Sep 25, 2009
I use siemens dishwasherand recently noticed some grit like substance left on my dishes etc after every wash
There should be a screen under the spray bar. Make sure that is clean. So "grit" is not recirculated in the wash cycle. Is "grit" showing up in your house water elsewhere? Check with clear water glass. Also consider testing with a competitive wash compound to see if there is any difference. A sample or from your friends.
Apr 14, 2015 | Siemens Dishwashers
Frigidaire dishwasher model#fdb105ores2dishwashersime friendly format 80e
Hello friend, thank you for your post!
Your water valve or spray arm could be the reason no water is getting to the top of your dishwasher. Remove the spray arm and clean it out with warm water. Also check to make sure that nothing is obstructing the spray arm from releasing water onto the dishes. I hope this information is helpful. -Matt
Sep 02, 2014 | Frigidaire Dishwashers
Dishwasher deposits dirt on dishes. Grit, small particles.
I have the same problem. We cleaned the dishwasher out because the grit was coming from the dishwasher...however, we still have dirt/grit in our dishes, but a lot less. How do we get rid of this all together?
Oct 03, 2010 | Maytag Dishwashers
Sandy grit left on dishes.
I was having a different issue with the same model but I think my issues solution might help yours. My dishwasher was not draining properly. It was the air gap that sits on top of the counter by the sink. It was clogged. We removed it and cleaned it out. Maybe if your air gap is slightly clogged as well it is not allowing the dirty water to flow out properly leaving you with gritty dishes. Hope this helps.
Jul 20, 2010 | Amana 24 in. ADB1200AW Built-In Dishwasher
Dishes and glasses are cloudy after competing the cycle. Do you know what I should do? Thanks
yes you need to get a good rinse agent like jet dry you need to use a ggood diswaher gel not powder and you need to buy a bottle of dishwaser cleaner add to an empty dishwasher and turn on closest hot water tap tto make sure water is hot going in to machine do this before you add jet dry to rinse dispenser i follow all instructions on bottle of cleaner it does a good job of cleaning all the **** that accumulates in bottom of dish washer works very good is around 8 bucks a bottle but well worth it
Dec 25, 2009 | Dishwashers
After a wash cycle my unit leaves a film on my glass'
first thing you need to do is purchase a bottle of dishwaser cleaner from your groc store in the diswasher detergent section red the instructions on the label add it to the cutlery tray in an empty dishwasher upside down remove the paper seal off the top of the lid do not remove the wax seal place the bottle upside down in your dishwasher turn on hot water tap and run till it is hot next turn on your washer set it to wasn and let it run a full cycle. when washer finishes open it up when it cools and fill rinse dispenser in door with a good quality rinse agent like jet dry close dispenser and when dishwaser is full of dirty dishes turn it on the jet dry will make your galsses come out crystal clear w no film and the dishwaher cleaner will help all your dishes come cleaner.Use the dishwasher cleaner aroun 4-6 wekks it cleans all the inside of the dishwasher and removes a lot of **** aND RESIDUE THAT ACCUMULATES IN DISHWASHERS OVER TIME
Dec 17, 2009 | Dishwashers
Dishes do not come out clean?
is the salt container cap damaged or loose? is the rinse aid topped up? if all ok then are you scraping most of the food from the plates, this can cause old food to mush, pulp and leave grit on dishes.
Mar 18, 2009 | LG LDF6810ST Stainless Steel Built-in...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
150 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
