Question about Mitsubishi WS-65807 65" Rear Projection Television
Can you connect to upconversion DVD Player for HDMI performance
I wanted to know if it is possible to use an upconversion DVD with my Mitshibishi WS-65807 television. The set does not have a USB connection for HDMI. Did not know if there was any way for this old an HD set to recognize the upconversion signal or any way to hook up the player to the set.
  • 1 more comment
  • bnmiel Dec 01, 2008
    I have a Mitsubishi WS-65807 65in. TV. It is 11 years old. I was wondering how do I hook up a Blu-Ray dvd player with a HDMI cable cord?
  • catzm Dec 02, 2008
    I'm trying to hook up my new Panasonic Blu-ray player to my old WS-65807, but the best I can get now is 480p. I know the tv is good for 1080i since I get it from my HDTV cable box.
    Any suggestions?
  • bAarond Jan 25, 2009
    I just got a PS3, and I really want to get full HD for the Blu-ray it has. My TV doesn't have a DVI or HDMI port. To get full 1080, is my only option get a new TV?
I couldnt get the dtv channel to work. (just a blue screen). i cant find the user manual, so all i did was plug in and change the input select of DTV to on. is there something else to do still?
Posted on Jan 01, 2008
    Problem Solver:
  • 6 Answers
The TV supports 1080i so if your hardware is plugged into the Component Cable Connection for Digital TV on the back the signal will come out 1080i as long as the hardware supports the size.
For example, my 360 is connected like this and when the dvd player is in use it upscales from the 480 format dvds use to 1080. More on the HD-DVD for the 360 and how it handles the sizes here:
http://www.engadgethd.com/2006/09/21/xbox-360-hd-dvd-playback-maximum-1080i-via-component-1080p-vga/
Kind of an old article since the newer 360s have hdmi and support 1080p that route.
Hopefully this helps.
Posted on Dec 26, 2007
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
I have a Sony STR-DA5200ES amplifier hooked into a sound system and a 52" Samsung LCD TV. The system is set up to operate on HDMI. The problem that has started recently is that the amplifier polls between...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings.
or
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The HDMI on the Sony STR-DA5200ES does not pass the audio. You need to either connect an optical or digital cable from your audio source. If it is a cable box or DVD player there should be audio outputs in addition to HDM.
Hope this will help...
May 25, 2010 | Sony STR-DA5200ES Receiver
I am trying to connect a DVD player with analog composite video connection with output to HDMI output. Audio works fine, however no video signal detected. Connected to front AUX connection and verified...
I would like to prove the video connector from the DVD to Aux (or wherever) works without upconversion to HDMI. Connect your monitor to the receiver's composite Out jack and see what happens with the DVD video.
Read and interpret the discussion on pages 22 and 100 very carefully to make sure nothing else is assigned to whichever video input path you choose for the DVD. Then try it somewhere else to see if that changes anything.
Jan 23, 2010 | Onkyo TX-SR606 Receiver
How is the DVD, Areal lead, XBox etc connected when using a 1910?
every device should be connected via composite, component, hdmi to the receiver. then the output of the receiver goes to the tv. youll have to check the upconversion capabilities of the 1910 to see what to connect to the tv. im not yet familiar with that model
Nov 03, 2009 | Denon AVR-2807 Receiver
With Cable connected to the rx-465 input, I'm not getting HDMI output to a Samsung plasma TV. With DVD HDMI input I get HDMI output to the TV. Any suggestions on what I'm missing. Thanks, Greg
is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings
Nov 03, 2009 | Yamaha RX-V463 Receiver
I get a "no signal" message when using HTMI or Component cables
on the remote, press "progessive" until you get a signal through hdmi to your tv
Jan 13, 2009 | Toshiba SD-K860 DVD Player
Upconversion to 1080i playback
Hey smittybd,
According to information provided by the manufacturer, this specific model DVD player is only able to provide upconverted 1080i images via its HDMI output and a maximum 480p resolution using its component connectors. Please keep in mind that while component cables are able to support 1080i and 1080p resolutions, not all hardware (TV's and DVD players) will support these resolutions through component connections.
If you're having difficulty locating a model that specifically supports 1080i resolution images through its component connections, you may wish to try visiting individual manufacturers' websites for more information. Some companies (such as Sony) will provide detailed information regarding what each type of connection is capable of in their owner's manual documentation.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 15, 2008 | Sony 36IN TV Stand Designed for Model...
Will not play HD DVDs. & will not record
First off this is not an HD dvd player it is a dvd player that has HD upconversion. secondly if you want to record a cable show you will need to push that into the dvd recorder with the a/v input.
Dec 29, 2007 | Samsung DVD-R135
Onkyo upconversion problem
I have a dvd player connected via component and I'm having the same problems. Manual via the On Screen Menu - Set the DVD input to "---" and the signal will be upconverted and sent via the HDMI out. This doesn't work for me so I might have other problems but if you haven't tried it, give it a shot.
Aug 16, 2007 | Onkyo TX-SR804 7.1 Channels Receiver
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
229 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
