Question about Remington Garden
Need air cleaner for a 754 super chain saw - Remington Garden
    President:
  • 2,220 Answers
Where is the spark plug as it needs changsd
  1. Remove air cleaner by unscrewing the knob A
  2. Remove air cleaner cover B
  3. Replace Spark plug
Jun 27, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Homelite 330 chain saw no lubrification to the chain
Allot of times this is caused by dirt plugging up the outlet. Pull the side cover that holds the bar on and clean using carb cleaner and compressed air. You should see a small metal tube or hole where the chain runs at the top, make sure it is clear. If you remove the cain and the bar you can start and rev the saw to make sure oil is weeping, it won't squirt out.
Mar 09, 2011 | Homelite ZR10926 16" Chain Saw
Chain saw wont run unless choke is on slightly
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. Make sure the carburetor is tight to the engine. Hope this helps!
Dec 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Can start the saw but when beginning the cut the saw power declines and will not cut. Please advise
The chain may need proper sharpening--it should not have to be forced to cut quickly. Make sure the bar and chain are being oiled enough. If the engine speed does not decline much, but the chain speed slows down, the clutch assembly may be full of oil (remove the cover and wash out the clutch with spray carburetor cleaner). Make sure the chain is properly tensioned--it should be tight to the bar, but able to be moved fairly easily by hand. Check the fuel filter and air cleaner for plugging. Make sure the fuel lines are in good condition. Hope some of this helps!
Nov 07, 2010 | Poulan Pro Chain Saw 46cc 20"
My super 2 homelite saw only runs on choke and don't want to run then
Check the fuel filter, air cleaner, and muffler for plugging. Inspect all fuel lines for decay or other damage. Make sure that you have fresh fuel-oil mix (50:1) and always shake the fuel can thoroughly just before refilling the tank to prevent oil starvation. Hope this helps!
Oct 19, 2010 | Homelite ZR10926 16" Chain Saw
I have stihl chain saw it runes full throttle
After you let off of the throttle it dies instantly or just kind of quits slowly ?
It could be :
- 1 ) Your clutch is hanging up and not allowing the engine to idle while the chain is not moving.
- 2 ) You need to set the idle higher. You will need to remove the air cleaner, and find the small idle adjustment screw, and turn the screw clockwise, until it idles.
Please let me know.
Feb 08, 2010 | Poulan Pro Chain Saw 46cc 20"
Cant find sproket number 76695
Super Deluxe ? Do you mean a Poulan chain saw. Check here they handle all brands of chain saw parts.
By the way Poulan is owned by Husquvana, which is owned by Electrolux.
sales@mfgsupply.com
Feb 04, 2010 | Garden
Where is the air filter on a homelite super2?
If you remove the top plastic cover on top of the saw, you will find the air filter under that cover.
Jul 05, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
90 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
