Question about Dell E173FPf 17" TFT LCD Flat Panel Monitor
Heard pop and had burnt smell from DELLE207WFP.
The monitor seems to be working ok but since the pop and burnt smell every time I turn on monitor there is a foul smell. Is that at all harmful to breath in? I can't purchase a new one at this time.
  • 6,831 Answers
Hello
The pop you heard was probably a capasitor. If i am correct the smell will get more prominet how longer the screen is on.
If it is a capasitor, which i believe it is, it will not be expensive at all to repair. Just take it to an electronic repair shop and let them just put in a new capasitor. The vapours of the smell is not deadly fo the small amounts of time and the concentration you are inhaling, but it gives me headaches.
Please rate this.
Best regards
Posted on Sep 25, 2009
Plugged in new oven heard a pop and a burnt plastic smell oven is dead
Call for warranty service it is in the owners manual I had a customer 2 weeks ago plugged in a 120VAC oven into a 120VAC outlet that was wired for 208/240VAC doubt if thats your problem but call for service
Jan 30, 2014 | Maytag 24" Built-In Single Electric Wall...
Electrical burnt smell
If you had a short in the starter motor windings and held the key, you'd get a click and a burning smell. That would be the insulation burning off the electrical windings. There's a 40-amp max fuse in this circuit.
Jul 21, 2017 | 1995 Chevrolet K1500
Transmission seems to slip more when it warms
Check ATF fluid level and condition. If its not burnt, smells burt and is pink without signs of foaming fluid is a-ok.
However, if it smells burnt and is a dark pink then the stator portion of the torque converter has failed and is not letting the converters' impellar and turbine produce the torque your demanding it to do.
Basically its time for a rebuild.
Jul 06, 2010 | 2001 Ford F250 Super Duty Super Cab
Last night I heard a loud pop sound come from my computer and then it shut down. I tried to start up the computer but it didn't turn on. None of the fans turned on either so I concluded something is wrong...
Yes, and the power supply needs replacing.
4 screws hold the power supply to the cabinet or case these are usually located outside visible at the fan vents at the four corners.
Apr 19, 2010 | Ultra Products Ultra LS500 Lifetime Series...
Heard a loud pop...saw a bright flash...burnt smelled and dryer stopped working. Circuit breaker will not re-set.
You may have a wire that has come loose of it's restraints and is rubbing on the drum as it turns. This would cause the wire's insulation to wear off, and if it's an electric dryer, you're dealing with 220volt wiring. The spark and burning smell is similar to arc welding.
You'll need to open the dryer up and find the damaged wire and reinsulate it with electrical tape or heat-shrink wrap.
It should be easily visible ...look for the burnt,blackened marks..
Nov 01, 2009 | Frigidaire Dryers
I was playing a game (PS3) and I heard a slight "pop" from the tv
User can't really fix this at all. Even a regular TV shop would have problem replacing individual components. What you can try to do is maybe order the board that has the burnt components, and raplace it yourself.
Jun 29, 2009 | Akai PT4799HD Rear Projection Television
Sony KP61V80
This may be an easy problem to fix. If you heard a pop sound, it's possibly a burnt cap on the powersupply. Check caps C521, C522, C517 or any burnt caps on the RA-3 chassis. Obviously be careful when checking.
Dec 16, 2007 | Televison & Video
Tv popped and shut off
Burnt small 2KV capacitor near flyback xformer....original is
221K....I use 271K / 2KV ...Possible burnt 1K 1/2 watt resistor
and shorted zener diode ....ECG 519..................T.
Dec 08, 2007 | Zenith B27A11Z 27" TV
Dell E173FPf 17" TFT LCD Flat Panel Monitor Logo
174 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
