Question about Fuji FinePix S5000 Digital Camera
I have a Fujifilm S5000. I love this camera. The
I have a Fujifilm S5000. I love this camera. The display will only show a white screen. I can view the pictures on the card on the display without difficulty, but when trying to take a picture, it is only white.
philipp
  • 217 Answers
SOURCE: Fuji S5000 will not diplay object on LCD Screen or Eye View
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager. check it out.
Posted on Sep 08, 2007
jackboy
  • 2985 Answers
SOURCE: Fuji FinePix S5000
This appears to be loose connector to the motherboatd from the screen.
Try gentle squeezing of the casing near the bottom of the body
This may do the trick- otheriwise it is a workshop job and frankly not worth the cost - the money would be better spent on a more uptodate camera.
Posted on Dec 13, 2007
pincer
  • 377 Answers
SOURCE: card error
TRY TO FORMAT THE CARD INTO YOUR PC, USING A MEMORY CARD READER.
Posted on Aug 16, 2008
Malcg
  • 32 Answers
SOURCE: Fujipix S5000 screen is all white
Suggest you book a repair for this problem at: http://www.fujifilm.co.uk/technical/camera_repair/
Posted on Aug 16, 2009
  • 275 Answers
SOURCE: FUJIFILM FINEPIX S5000.No image on viewfinder or LCD.
I think there is a small button on the back of the camera near the bottom that turns the viewfinder off and on I think. It should be in the manual.
It might have gotten bumped while in the bag.
Posted on May 24, 2010
My view screen is white but I am able to view my pictures on my memory card
Most likely a dead CCD (imager) unit. Happens to these cameras. Usually they are supplied with the lens and are expensive if ordered from Fujifilm - could be about $200-300. I wouldn't recommend using used parts because they could break down again sooner or later. I suggest you buy a new camera.
I have worked for Fujifilm.
Tom
Mar 05, 2011 | Fuji FinePix S5000 Digital Camera
I have a FujiFilm S5000 and since 2 weeks the sensor seems not to be able to adjust when trying to take a picture in sunny condition. The screen shows white and pink colour with horizontal lines. I turn...
Actually it's not the sensor it's the LCD screen. I would say in the last two weeks the camera didn't change but the environment it is being used in has and is causing the camera to overheat.
Diagram
Temperature
Diagram
Keeping the camera within these perimeters should solve your problem.
Jan 18, 2011 | Fuji FinePix S5000 Digital Camera
MY finepix s5000 fujifilm camera has a white screen displaying when i turn it on, is there anyways i can fix that problem with out haveing to take it in.
Had the same problem with my s5700, white screen, took it apart. two screws on the left (facing the screen) under the strap, two in the usb compartment, two (screen side) screws on the bottom, three screw in the battery compartment, and the final just below the right side strap. Carefully pull the back off and check the ribbon connection from the lcd to the board. push it in made sure its seated. Reasemble being careful not to bend the ribbon connectors. Worked for me.
Aug 05, 2010 | Fuji FinePix S5000 Digital Camera
My s5000 screen is all white in record mode. It breifly had a picture then when I pushed the shutter it went white again????
Does the EVF work? The small view finder above the LCD screen. You can switch to it using the EVF/LCD button on the right side above the main display. If it is okay then you'll likely need a replacement LCD.
Jan 04, 2010 | Fuji FinePix S5000 Digital Camera
I just started having the same problem with my S5000, also.
Jul 11, 2009 | Fuji FinePix S5700 Digital Camera
I have a fujifilm finepix S5000 when camera is turned on it just shows a white screen. Cant take pictures, movies, nuffin works. Can u help, please.
if u see white screen and lcd show info and signs and pictures also turn out to be blank when u see them on pc
CCD Failure has occured !
dont worry i have the same problem with my S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this
http://www.imaging-resource.com/badccds.html
for support in usa or select different region www.fujifilm.com
http://www.fujifilmusa.com/support/ServiceSupportContact.do
Apr 09, 2009 | Fuji FinePix S5100 Digital Camera
View screen lights up but no display
if u see white screen or noisy picture on lcd and lcd show info and signs and pictures also turn out to be blank when u see them on pc
dont worry i have the same problem with my Fuji S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this
Apr 08, 2009 | Fuji FinePix 2650 Digital Camera
Change from black and white to color
There is a little blue button next to the LCD button, directly above the display screen. There are alot of controls when you press, like color, B&W, shutter speed, etc. Thanks
Sep 29, 2008 | Fuji FinePix S5000 Digital Camera
Display not showing correctly
I had the problem, got the CCD changed it worked for a few months then it stopped working once again. My advice, though its a great camera its time to retire it. Problem is I just love the ability to add on filters which is not common in most prosumer cameras
Jul 09, 2008 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
27 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
