Question about RCA HD50LPW42 50" Rear Projection HDTV
RCA 61" TV (HD61LPW165) Lamp Fan making noise
Lamp/bulb cooling fan is making a squealing noise. The number on the fan is AFB0812LL. Where can a replacement be purchased? How does one make the actual replacement in the unit?
    Welcome Back:
    Visited the website for 2 consecutive days.
Here ya go:
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&productId=662661
Much better longer life part. 80x80x25 mm 35 cfm with rotor lock wire. Connect the yellow to the blue wire on the tv, black to black red to red.
Posted on Feb 10, 2011
Lost picture but sound is on
almost certain this is a lamp problem, bulbs blow up
if you remove the lamp you can see if the bulb is broken inside.
Jul 19, 2010 | RCA HD61LPW165 61" Projection HDTV
Is there a led replacement bulb for the rca m50wh72s? the bulb 270414 lasts only 9mos tired of spending 120$ every time to replace this
No, LED light engines are different than Mercury Vapor lamp engines. They have different power supplies and different control boards.
Mar 14, 2010 | RCA HD61LPW165 61" Projection HDTV
How to replace faulty lamp cooling fan on HL-P6163W TV
A more likely candidate is the color wheel,unless your sure it's the fan
Dec 01, 2009 | Samsung HL-P6163W 61" TV
Loud noise coming from Lamp area
The fans in these generaly do not go bad, the part nubmer for the lamp cooling fan is 265943. But my guess is that the color wheel is starting to go out of you light engine. I am not sure if these are still avalable but the part nubmer for it would be 267888. Worst case you could send your engine in for repair engine nubmer should be 265864 or order a repacement try this site. GOOD LUCK http://www.moduslinkptstvboards.com/Default.aspx
Aug 13, 2009 | RCA HD50LPW165 50" Rear Projection HDTV
Loud squealing noise first 5 minutes after tv is turned on
Sounds like the color wheel. It's the only moving part in most DLP's and the bearings can go bad. If it manages to get up to speed the picture may look normal. One temporary solution may be to let it run a few minutes, then turn the set off for 10 minutes, then turn back on. When my color wheel was going bad that would often quieten it down. For the rest of the day, try to leave the set on, especially if you're only going to be away from the TV for short periods. You can turn off your cable or satellite box but leave the set on and you won't have to go through the hassle of trying to quieten down the color wheel until the next cold start. Of course the best solution is to replace the color wheel which even with a rebuilt unit won't be cheap if your warranty is expired.
Nov 02, 2008 | RCA HD61LPW165 61" Projection HDTV
FRUSTRATED SPORT FAN
We would not be able to tell you that type of information since we do not know the company you purchased it from. However, Andrewselectronics.com has lamps for that unit in stock. Please list your complete model number or the part number you were attempting to purchase and I can let you know if it is in stock at that website.
Mar 25, 2008 | RCA HD61LPW165 61" Projection HDTV
Buzzing sound by bulb
be quite sure that it is not the fan physically touching the case; other than that, scope your B+ voltage to the ballast and be certain it is clean;  while it could be that or the lamp itself, it is most probably loose or misaligned case assembley
Oct 09, 2007 | RCA D44LPW134 44" HDTV
RCA HD50LPW42 50" Rear Projection HDTV Logo
324 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
