Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I heard a dripping sound and discovered it was coming from the back of the freezer. I also noticed the infrared receiver light is flashing red...what's up?
  • 30 Answers
The common thing is the water line hook up to the back of the frige. First find the shut off. It is usually under the sink or behind the fridge. Roll the fridge out slowly so as not to damage line further. Also roll it straight as not to damage floor. Once u turn off the water line listen to make sure the water drip has stopped if it stops thats the problem. The line is very easy and simple to change yourself. You can get the plastic ones or copper one at the home centers.
I heard a dripping sound and discovered it was - moz-screenshot-1.jpgThe water shut off can look like this behind fridge....
http://img.diynetwork.com/DIY/2003/09/18/dpb105_1fw_lead.jpg
or like this if its under sink either way follow the line from fridge to find it.
http://www.howsed.com/wp-content/uploads/2008/03/disconnect.jpg
Posted on Sep 25, 2009
My wife noticed our side-by-side GE Turbo Cool water dispenser was dripping water so a quick look in freezer showed a huge ice buildup in the drip tray that had frozen back into the spout. We emptied both...
let see if I understood correct me if i'm wrong! When you close the freezer door water star running from the dispenser? If so you water valve solenoid is staying in the open position just replace it.
Dec 21, 2014 | Refrigerators
Tfx28pbba
Actualy, it sounds like you merely caught it right when it went into defrost cycle. If it's a non-electronic (non-chinese) model, it probably has an electro-mechanical timer for the defrost which you can manually advance until the compressor comes back on.
Otherwise, just leave it plugged in and set at the default temperatures until it comes back on of its own accord. Defrost time could be in the neighborhood of 20 - 30 minutes. This can occur 3 - 4 times in a 24 hour period.
May 27, 2014 | GE Refrigerators
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
LG42PC3D TV - No remote control. Manual control works.
dont blame the receiver yet, the problem mostly comes from the remote control. it may be the infrared emiting problem. checkout if the infrared in the remote control is emited well. to see this infrared you can read the article at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
good luck
Dec 05, 2009 | LG 42PC3D 42 in. Plasma Television
Water dripping in the freezer We have side by side kenmore fridge and freezer and filtered water. I just opened the freezer and heard dripping of water behind back cover. It sounded as water is hitting...
this IS normall. the freezer is just in defrost cycle. the heat elements are on and defrosting the evaporator. you are hearing the water hitting the elements and running to the drain. this is normall, does it every day, just the first time you happen to notice it. shane
Aug 25, 2009 | Refrigerators
Odd sound from freezer area
If it is still under extended warranty I would have a service call made. It sounds like the dc motor on the circulating fan is starting to ware out.
Jul 14, 2009 | GE Americana 15.6 Cu. Ft. Top-Freezer...
Glowing light and warm air freezer side
HI thanks for your question. you found your freezer in a defrost cycle, which is normal function.the defrost cycle happens every day every 10 hrs. on for about 20 min. then resumes the cooling cycle. so its normal. thanks the appliance doc, please rate my answer. thanks.
Oct 12, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Water dripping inside fridge
OK, i see a lot of this, and on a fridge that is nearing 10 years old, its pretty normal. Now, we all know that water is leaking into the fridge section from up top because the drain is plugged that is under the evaporator.. now to fix the WHY it happened. most of the time this will happen because the fridge did not go into a DEFROST cycle for a while.. reason being one of two things... either the defrost timer has quit working, or the bimetal thermostat sensor that is clipped on the evaporator has failed. the bi-metal thermostat is usually located in the freezer behind the rear wall and looks like a round "clip on" with 2 wires coming off of it. one pic of one is here.
http://www.partselect.com/PartDetail.aspx?Inventory=371255&SourceCode=5&ModelNum=et18pk
instructions on how to test this is shown on the link.
(just replaced mine the other day, NO MORE WATER LEAKS! =) )
hope this helps!
Chris
Jun 15, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Jul 13, 2007 | KitchenAid Superba Architect KSCS25IN Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
137 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
