Question about Pentax Optio A10 Digital Camera
Pentax A10 Have a three month Pentax A10 digial camera, with no previous problems. It now cannot read the SD memory card and won't take pics when the memory card is in the camera. This memory card will work in other cameras. Able to take a photo when the memory card is out of camera. Tried a different memory card - same problem. This happened after I took the card in to Walgreens to get some prints made. Can taking the card out of the camera and putting it back in damage the part of the camera that reads the card? If so- what do I do?
  • 1 more comment
  • WinstonSmith Mar 11, 2008
    "Card not formatted" displays at power-on, no matter what card is used.
    Cards are fine in all other devices.
    Attempting to format card in camera causes power-off.
    Camera will take photos using onboard memory.
    Pentax says, "Always format card in camera" and "Send camera in for repairs". (Not likely...)
    I suspect this is a firmware rather than hardware failure.
    (USB cable connection to PC also failed months ago...)
    This camera has been a disappointment since Day 1.
    I suspect I'll trash it and get a Canon or Sony
  • ThaFormula66 Dec 04, 2008
    I also have a similar problem with my Pentax A10, when i put a Card in it : Memory Card Failure but i can make pics with the build in Memory !
    Thanks
    ThaFormula66
  • tanialcuella Jan 18, 2009
    Once I put in my SD Card the camera freezes and won't even power on or off. Camera works fine without the SD card. I have tried a 4G SD and also a 1G. Two different brands.
  • 4 Answers
Try another card in your camera but check the inside the card holder that you have not got a damaged connector in there. and format the card with the camera and not on pc. Hope that help you.
jam
Posted on Jul 03, 2008
Memory card error
What type and size memory card? The A10 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Feb 05, 2013 | Pentax Optio A10 Digital Camera
A10 Card locked
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 11, 2011 | Pentax Optio A10 Digital Camera
Hi, i have some photos on my internal memory and need to put them on an sd card because the connection with usb is faulty. As soon as i put an sd card in camera i cant see internal memory images. Is...
There should be an internal transfer from memory to SD card on most camera but not all look under the main menu for the memory card where it tells you to format card and create folders it there should be a COPY option.
Dec 06, 2010 | Pentax Optio A10 Digital Camera
I have a brand new PENTAX E70L camera, with SD memory card. i took a few photos on it and then turned it off. Now when i turn the camera on it reads -card requires formatting.I press continue , to format...
Make sure you don't have any pics on the internal memory. To be sure, with no card in the camera, go into the menu and find "format" and follow the on-screen instructions. Then, insert the card and go into the menu and do the format thing again to erase the card and optimize it. Use the menu and not the format option the camera has been giving you.
Sep 28, 2010 | Pentax Cameras
What is the maximum size sd card for a Pentax Optio A10? The 4 GB card is not being recognized by the camera (which I just got).
The A10 accepts SD cards, which max out at 2Gb. The 4Gb card is actually an SDHC (Secure Digital High Capacity) card, not an SD card, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Dec 26, 2009 | Pentax Optio A10 Digital Camera
When 4 gig. sd hc memory card is loaded into camera CARD IS IN ERROR msg. appears on lcd screen. Any ideas???
The A10 uses SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with the A10. You need to use SD cards, 2GB and smaller.
Apr 12, 2009 | Pentax Optio A10 Digital Camera
Problem transferring pictures to PC
do you have the ability to attempt transfering the pictures onto another computer  maybe its just that computer  what type of card reader are you using  is it factory installed or aftermarket try installing a different card and see it you can transfer pictures from your camera to the computer then  maybe its a file type(format)problem  theres what i have good luck   let me know how it goes
Mar 28, 2009 | Pentax Optio A10 Digital Camera
Transfering pics from camera built in memory to SD memory stick.
Go to the playback menu, scroll down to the option <copy>. It might be in the Setup menu, but I do believe it's in the playback, copy, OR playback, Setup, copy. have card in camera.
Aug 17, 2008 | Pentax Optio A10 Digital Camera
Downloading videos to computer
Are you using a USB cable to the computer or a SD card reader??  If you are using a cable, then buy yourself a USB card reader and it might work then.
So you can't get the videos on the computer at all?
Or you can get them on there but they won't read properly?
Cheers
Emmanuel
Jul 06, 2008 | Pentax Optio A10 Digital Camera
Memory card not working
Not saying it is, but are you absolutely sure its not the camera software itself. Does it have any warranty? Is the card a new card and have you made sure that the TAB on left of SD card is not allowing READ ONLY. The tab flips up allowing the card to be formatted bit like the old floppy disks.
Apr 26, 2008 | Pentax Optio T10 Digital Camera
Pentax Optio A10 Digital Camera Logo
205 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
