Question about Sport & Outdoor - Others
EZ Go Golf Cart inoperable, batteries fully charged, 36 volts
  • rablf Sep 25, 2009
    yes
    President:
  • Sport & Outd... Master
  • 1,922 Answers
Does your forward/reverse on the pedal actuate in either direction?
Posted on Sep 25, 2009
  • daniel  hendrickson
    daniel hendrickson Sep 25, 2009
    then you have a switching relay problem on one of your relays, possibly depending where the relays are located,corrosion from the battery
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Wiring diagram for EZ-GO Marathon 36 volt golf cart
Excellent......asking for a Golf Cart wiring diagram in a Water Heater posting board....
Works for me
I have a Westinghouse Nuclear Reactor I bought used from the USN. Can you tell me where I buy the Heavy Water for it????? Kroger? Safeway? Whole Foods?
Oct 20, 2014 | Water Heaters
How to get More power out of a EZ go golf cart
I need to know whether it's a 36 or 48 volt cart. You can get a freedom chip for about five bucks that would give it more speed or torque depending on which you're looking for. If you have money to spend you could upgrade your controllers as well as your batteries as well as your battery cables. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Sep 08, 2014 | Golf
Golf cart wiring
Its been a wile but if I remember right it goes from the solenoid under the cart (pass side) to the key switch (the other wire is probably volt meter) then micro switch,green wires from micro switch to controllern. Inspect all spade connections
Jan 30, 2013 | Cars & Trucks
I have a 1995 ez go electric golf cart.when it is fully charged i drive it and i start losing power.then i put it back on the charger it is only one third charged.I checked my batteries with a metor and...
if you didnt check the amperage the battery is going bad it may read 12 volt or 36 volt depending on the wiring but if it will only charge a 3rd of the way then the battery needs to be replaced because the amperage is not there to completely charge so it will lose power do to lack of voltage/amperage.
I hope this helps
Sep 02, 2011 | BMW 318 Cars & Trucks
How to wire a 12volt lights to a 36 volt system on an E-Z-Go golf cart
all you have to do is run the positive wire from the lights to the positive post of one battery and the negative wire to the negative post of the same battery. You will be using just one battery to power your lights. Hope this helps
Oct 19, 2010 | MK Battery Golf Cart 12 Volt Sealed Gel...
Want to connect electric lights to ez-go electric golf cart. It is a six battery system and I want to simply add a front light and rear red light.
You said you have 6 batteries. Are they 6 volt or 8 volt? Hint-- 6 volt has three holes in the top and an 8 volt has 4 holes on top of the battery. Battery manufacturers recommend the use of a voltage reducer wired to the whole bank. This take the 36 or 48 volts down to 12 volts and is regulated. this is recommended so as not to stress just 2 batteries. If you have 6 volt batteries, you can use any 2 that are wired in series.
Sep 21, 2009 | Garmin Walking Cart Mount For Golflogix...
Ez Go 28115-G01 battery charger does not work.
I have an EZGO powerwise 36V charger, model 28115-GO3 that was installed onboard a cart. I want to use this charger for another cart, but the charger has 3 wires out. Why 3 wires? One is +, the other -. what do I do with the third wire? The wires are red, black and yellow; two odf the wires are 10-12 gauge, the other is around 16 gauge.
Mar 26, 2009 | Electronics - Others
Sport & Outdoor - Others Logo
204 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
