Question about Olympus Camedia Stylus 300 Digital Camera
There is write protect error and i can't take pictures
  • 30 Answers
If the camera has an internal memory and that is where the pics are being saved to i need the model number. But in the mean time if you are using an sd card try pulling out the card. Some cards have a slide on them that locks the card so you cant write over pic. What happens is some times handling the cards and inserting them the slide accidentally gets moved. this link is to a picture of the lock.
http://www.pocket-tunes.com/images/kb/SD%20card%20lock%20slider.jpg
Posted on Sep 25, 2009
Memory card is write protected error
remove the memory card and look if the switch is in the up position. On the picture the little yellow notch on the left.
On this picture it is in the correct position. If pressed down, the card is write protected (Called LOCKED)
Jul 23, 2014 | Nikon 26300 Coolpix S6300
I have a Kodak Easy Share C182 . I want to delete some pictures and it tells me to remove protection to delete, and it also tells me image is protected please tellmje stepby step how to clear this...
The most common cause for telling you that the card is locked is having the tiny slide switch on the side of the card in the wrong position.
- see photo below:
Set the lock slider to locked or unlocked.man-3ds-sdcardlockswitch-287-181.png
  • The down position will enable write-protection, locking the card.
  • The up position will unlock the card, enabling you to save and erase data on the card
kodak-easy-idhgrcvb3gwnj1x0htsxmiux-2-2.jpgthe tiny slider is labeled with "Lock"
SD memory card lock Nikon Knowledgebase
Dec 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
'olympus stylus 710.When i try to take pictures or erase them it would say write protect or picture error how to i qet it off
Look at your memory card it may have a small switch to protect pictures from being erased or changed. Download what you have taken and reformat card.
Nov 08, 2009 | Olympus Stylus 710 Digital Camera
Transfer pictures
Dear remove the write protection on your disk to eliminate this message, you computer or fram memory is write protected. check the properties of those and remove if they are write protected. this is resolve your issue.
Good luck in correcting your problem.
Best regard
May 27, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Olympus 850sw- write protect and picture error
Sounds as if the memory card has corrupted data on it now. You will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup Menu - right arrow to Format- Press Ok. You will see format yes or no. Choose Yes and press ok. This will clear the write protect and picture error messages and the card can be used again.
Dec 29, 2008 | Olympus Stylus 850SW Digital Camera
Removing write-protection from down-loaded pictures
You cannot do that if you're refering to an album cd disk, make sure that you have a cd writer and a multi session recordable disk
Jul 08, 2008 | Kodak EasyShare One Digital Camera
Motorola
on the camera settings , have you got it on to share or to protect if so deactivate the protect on the pictures. before trying to send them again.
May 13, 2008 | Motorola Mobility RAZR V3m Cellular Phone
"Write Protect"?!
It's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 27, 2007 | Olympus Stylus 600 Digital Camera
Mitsubishi VS-45607 picture goes out intermittently
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Dec 13, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Olympus Camedia Stylus 300 Digital Camera Logo
90 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
