Question about Canon CanoScan LiDE 70 Flatbed Scanner
It give code 2,179,0. release the lock stwitch. detach the I/F cable and reconnect
fixjd
  • 5 Answers
SOURCE: canon scan lide 20 Message: Release the lock
Check the bottom or side of the scanner for a sliding lock.
Posted on Nov 23, 2009
  • 111 Answers
SOURCE: Canon LIDE 500F scanner does not scan - returns error message about releasing lock switch, detaching interface cable and reconnecting
Check the lock switch and make sure it is unlocked. I think the lock switch is on the bottom...or it may be under the lid near one of the hinges. Flip it back and forth and leave it in the unlocked position.
If this doesn't work, then it will most likely need service. Contact Canon Tech Support.
Posted on May 09, 2008
xptareq2000
  • 1447 Answers
SOURCE: CanoScan Lide 25 - cannot use the scanner at all.
this lock is front top side or down side please unlock position
Posted on Sep 06, 2009
SOURCE: message received Release the lock switch,detach
Uninstalled software, disconnected usb cable. Then reinstalled software and reconnected usb cable.
All up and running!
Posted on Nov 24, 2009
SOURCE: Canoscan lide 20 Error; Release the lock switch, detach the USB cable and reconnect. Scanner driver will be closed.
where place of the "Lock Switch" i want to unlock becuse i get problem for that
Posted on Apr 22, 2010
I have problem with my canon Scanner 110 lide
Disconnect the USB (which is the power source) and install the driver. Then reconnect the USB. The driver should be detected automatically. Go into "Device Manager" to check.
Jan 01, 2015 | Canon CanoScan LiDe110
I cannot scan with my scanner: " it says RELEASE THE LOCK SWITCH,DETACH THE USB CABLE
Hi ,
Disconnect your unit from your pc ( usb and power)
Insert your install cd and run the program
Restart your pc
When Windows has settled , connect scanner back to pc .
It should run normaly .
Best regards.
Aug 15, 2014 | Canon CanoScan LiDe110
I just installed my new Canon LiDE 110 scanner. I slid the lock button to the unlock position. When I try to scan, I get the following error: "Release the lock switch, detach USB cable and...
mbrindle is great!!!! Many thanks - I was just about to take it back as I thought the scanner was defective. Would never have thought i had to do that. Thanks!!!
Aug 15, 2011 | Canon CanoScan LiDE100 Flatbed Scanner
How do I remove the ignition tumbler on a 1992 Explorer?
  1. 1 Open the hood. Disconnect the cable from the negative battery terminal. Peel back the insulator if equipped, and use the wrench to loosen the clamp nut on the negative cable.
  2. 2 Remove the covers on the steering column. Use the screwdriver to pull out the screws, and detach the knee bolster below the steering column. Pull out the screws and detach the lower cover to find the screw for the upper cover; then remove the upper cover in the same manner.
  3. 3 Remove the multifunction switch by pulling out its retaining screw and pushing on the release lever to detach the switch from the column.
  4. 4 Disconnect the ignition switch's electrical connector. Then detach the switch from the steering column by pressing on its clips to release the tabs.
  5. 5 Install the new ignition switch in the old one's place, making sure the locking tabs activate and the spring under the switch is in position on the column's locking rod. Connect the electrical connector.
  6. 6 Reconnect all other parts on the steering column in reverse order of removal. Replace the negative battery cable.
  7. 7 Insert your ignition key to test for proper operation in all three positions: "Lock," "Accessory" and "Start."
Jan 22, 2011 | 1992 Ford Explorer
Message received Release the lock switch,detach the usb cable and reconnect. Tried this but it doesn't work. The scanner is not locked!
All up and running!
Nov 23, 2009 | Canon Office Equipment & Supplies
hi.. there is a lock under the scanner you need to unlock it... lock it to prevent damage while transporting...
Dec 16, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Canon 8400F Scanner keeps returning ERROR: release lock switch, detach I/F cable and reconnect. The lock switch IS in the unlocked position, but scanner will not scan.
Have exact same problem on a Canon scanner (N1220U) which is several years old. Suggest you uninstall the driver software and reinstall it. I did and my scanner is scanning fine again.
Jul 08, 2008 | Canon Office Equipment & Supplies
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
2,092 people viewed this question
old marine
old marine
