Question about Samsung Instinct Cell Phone
My samsung instinct is not charging properly. I plug it in with my charger and the charging screen appears for less than a 30 seconds then goes to my background display. I have tried using my car charger and the same thing happens. It wont' charge past 70%. I have not dropped my phone, gotten my phone wet or done any damage whatsoever. In fact, I'm very careful with my phone and keep it in a case at all times. This has been going on for about 5 days. What do you suggest?
  • 33 Answers
Look inside the charge port to see if there is anything from the charger inside that my have broken off by accident. that is very common with the instinct and the m300 as they use the same style charger. you may need to just replace the charger. and if the phone is in fact broken, sprint has an insurance plan that will get you a new one for free or for 50 bucks depending on the policy
Posted on Sep 25, 2009
Samsung 3262 charging paused for battery
Since you are experiencing difficulty in your charger since your Samsung 3262 won't charge although it is showing it is charging battery then we will be solving this matter so to fix battery and charger problem. • Performing a power reset. •Hold the power button for 30 seconds without it being plugged in. •Then place your Tab on a home charger for a couple minutes. •After a couple minutes, press the power button again for 30 seconds with the charger plugged in. This is usually a charger issue But in a small amount of cases it can be the battery. If recently purchased you can just return it and get a new phone.
Sep 29, 2014 | Cell Phones
My Samsung galaxy prevail suddenly reads and wont accept a charge. Im using the original "samsung" home charger. A small yellow triangle with a smaller image of a battery crossed out and appears within...
I would check the connection to the phone make sure it was not damaged and I would try a different outlet or a new charger before having to send your phone back ...
Jun 13, 2013 | Samsung Galaxy Prevail for Boost Mobile...
Kindle does not charge properly
Let's try to reset the charger system.
Step 1: Unplug from the charger, press and hold the Power button for 30 seconds
Step 2: Plug into the charger. Press and hold the power button for 30 seconds
Step 3: Let charge for 12 hours
Step 4: Unplug form the Charger, run the Kindle until totally dead.
Step 5: When DEAD. Press and hold the power button for 60 seconds.
Step 6: Plug into the charger, let charge normally
If this does not reset the charging system you have either a faulty Kindle or a faulty charger, contact Amazon for replacement.
Apr 01, 2013 | Amazon Kindle Fire HD
Mini 1012. new battery. charger led working, battery wont charge. when plugged in charger works for about 30 seconds
Seems like you may have purchased the incorrect battery or they shipped you one that is NOT for your unit, if you purchased an "aftermarket" battery this could be the issue. Not saying aftermarket parts are bad, they are just massed produced and sometimes you get a bad one. Return it for refund or replacement. Try E-Bay for a reseller for this product, much less cost.
Jan 28, 2013 | Dell Inspiron Mini 1012 Netbook...
Samsung sch-u340 wont start up
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 07, 2012 | Samsung SCH-u340 Cellular Phone
It will not turnm with out the chager and it is chager all the way
Dear, you must change your battery, i mean get a new battery and then charge it. So after it charge unplug charger and turn on the phone.
Thank you
May 16, 2010 | Samsung FOR SAMSUNG INSTINCT S30 M810...
The charger slot on the phone does not work when plugged in, think it needs a new port
Why don't you use the charger to charge a similar phone or use a similar charger aside yours to charge your phone to see if it is the charger or the charging port.
If your charger charges a similar phone as yours, it means the charging port of your phone is bad.
But if it does not, the charger is the problem.
If it is the charging port, all you need to do is to replace the charging port and your phone will charge.
Take care.
Apr 21, 2010 | Samsung Instinct Cell Phone
Samsung flight quit charging
Try charging the phone until it has finished charging.connect the charger and charge for 2.5 hours.
The battery icon on the screen may not appear for 30 mins.
You can also go to a dealers and ask to try a new battery, or and a different charger.
If none of the above work ring your network supplier and ask for a replacement phone.
Jan 12, 2010 | Lands Phones
I took the phone off the charger one day and it wont power on
Then its the motherboard inside the phone where the charging port connects. It costs about 150-200 to fix unless you have sprint insurance. This happens if the phone is accidentally dropped JUST wrong still plugged into the charger, or if the charger is taken out JUST wrong and sideways or crooked. On a plus side, it is a common thing for a lot of phones and it is fixable by a technician.
May 06, 2009 | Samsung Instinct Cell Phone
Samsung Instinct Cell Phone Logo
211 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
