Texas Instruments Voyage 200 Calculator
Problem for Texas Instruments Voyage 200 Calculator
TI Voyage 200 Calculator:\r\nBlank vertical lines
By mafejo on Sep 25, 2009
TI Voyage 200 Calculator: Blank vertical lines are appearing on the screen.
The solution to this problem for Franki_01:
Where is the electrolytic capacitor?
Among U3 & U4 not see it.
http://www.datamath.org/Graphing/JPEG_Voyage200_A.htm#row
Solution for Frankie_01:
Hi, and sorry for my english !
Maybe the LCD driver voltage is wrong or noisy. I had the same problem: some vertical lines (not constant), pulsing contrast after powerup, pixel crosstalk, sometimes no screen
Solution: Try to replace the LCD power negative voltage buffer capacitor.
In my hardware version it is in the middle of the two T6B07 column driver IC (U3&U4) on the right side. Colored black, electrolytic type and the Value is : 10uF/25V. Chage it to around the same type.
There is enought space, so you can use a small sized non smd type capacitor. Be care of the polarity.
I hope it will help... ;)
Greetings from Hungary!
Thanks and best regards
Popular Solutions for Texas Instruments Voyage 200
Questions and Unsolved Problems for Texas Instruments Voyage 200
Do you recommend Texas Instruments Voyage 200 Calculator?
Answer
Answer
my voyage 200 completely drains my batteries within 3 hours. It had not been used for few years.... (More)
Answer
I also have the same problem, but when my calc is ON for an hour or more, then they disappear. It's... (More)
Answer
How do I create a program in the program editor that does the same as the Solve, when I have the... (More)
Answer
When I press the "On" Button, the calculator screen becomes black for a very short time... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Calculators Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
