Goodman AR-36-1 10kW : the blower won't start, though i can ear the relays and the freon is circulating, i noticed that the exchanger was full of ice, is this possible that the fan had overheated ?
  • 4 Answers
Either blower motor or capacitor is out.
Posted on Sep 26, 2009
My goodman split system AC unit is running but the fan won't run even when I switch it to fan on thermostat. Any ideas please?
Did you notice if there was a click at the blower cabinet when you were switching the fan switch back and forth? If it clicks you probably have a bad fan motor. If it doesnt you may a bad thermostat, relay or relay board. Hope this helps good luck
Aug 14, 2013 | Heating & Cooling
94 Buick Roadmaster AC fan blowing hot and won't shut off
If you have climate control it could be the main processor. Something could be shorting the blower relay to keep it on. You would also need to check and see if the system is still full of freon.
Jul 06, 2013 | Cars & Trucks
Will no freon prevent me from adding freon if the compressor wont engage without it
Sort of.
If the system is empty, you would need to jumper the low pressure switch to power the ac clutch to put the first can or two of freon in.
Keep in mind the system is supposed to be vacuumed out before adding freon, so if it is full of air you won't be able to put the full amount of gas in.
Sep 28, 2012 | 1999 GMC Suburban
Just installed new Goodman 95% updraft furnace with 3" supply and vent lines going out through wall. Gas valve won't open. Circulation blower runs in manual on, A/C system runs fine. I have used an...
Make sure you have bled your gas lines. If any air is in the lines, it will cause the unit to do exactly what yours is doing. The relay "click" you hear is the gas valve opening, but if there is no gas, it will not ignite. This is common for a new install. I hope this helps or at least points you in the right direction! Good luck!
Sep 27, 2010 | Goodman Heating & Cooling
I have a Goodman GMH950904CXAC. Thermostat calls for heat. It comes on and runs fine for about 5 minutes, then the circulator blower shuts off, but burners and draft blower still run. After another 15...
4 flashes is an overheat situation most likely caused by the blower not blowing. The blower relay controls the blower function. It is part of the circuit board. I suspect a new board will take care of the problem if you don't find a lose wire or something simple.
Feb 27, 2010 | Goodman Heating & Cooling
Having a problem with a goodman gas furnace, pilot starts and burners fire up, blower starts and burner goes out after like 5-10 seconds. Blower continues to run but only circulates cold air. burner does...
Sounds like the rollout is being tripped from the blower moving the falmes. i would have your heat exchanger checked for cracks or holes as this is usually the reason the blower moves the burner flames to tripp a rollout.
Feb 22, 2010 | Heating & Cooling
Hi, just replaced the capacitor thinking that would solve the problem but it appears it did not. The motor outside would kick on the unit inside would kick on but the blower motor inside works sometimes...
Turn off the power to the air handler(indoor unit). Remove the access panel. From the motor,trace the wires back to the fan relay. One wire will probably trace back to the incoming power terminal. The other is the fan relay. It could be intermittent thermostat signal to the relay or a bad relay.
To verify if the fan motor is good,you can remove the one wire from the relay and re-attach it to the other side of the incoming power terminal. If it runs OK there,replace the relay. If it does not run,replace the blower motor.
Sep 28, 2009 | Heating & Cooling
Two and a half ton Goodman Package Unit
goodman boards really have to have a very good ground. make sure the ground wire is securely attached. also even though you say the limits are all good, you need to check the wiring that goes from one limit to the next. they should make a loop that goes from the plug at the control board to each limit and then back to the plug. take the plug loose and locate these 2 wires. ohm them out. if it is open, your problem is somewhere in the loop. the fact that the blower is running all the time tells me the board is not getting the signal it is looking for from the limits. I have seen some goodmans that have a rollout problem at the burner box and it melted the wiring to the limits on top of the box.it is hard to see so you have to look closely. also if this is the case, you need to have someone check the heat exchanger for a crack. the rollout usually does not happen till the fan starts blowing while the burners are on. if this is the case, you do not want to run the furnace for any reason as this is a carbon monoxide risk.
Jan 27, 2009 | Goodman CLQ36AR49 Air Conditioner
6 blinks
sounds to me like i wish i could find out if this is new install or if the electric has been changed recently,,,sounds like reversed polarity on the plug,,,which means the white and black wires need to be swapped. If there has not been change recently than u need to see the other post i made on goodman about the combustion fan motors and there types and fixes. But almost certain that is reversed polarity. good luck
Oct 23, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
