Question about Music
Rewireing pedal board wires.
I HAVE A SUZUKI HP-97 DIGITAL PIANO.I MOVED IT AN THE WIREING PULLED OUT OF THE PEDAL BOARD.SO I'AM LOOKING FOR THE CORRECT ORDER TO REWIRE THE PEDAL BOARD.
THANKS,JOSH
  • Music Master
  • 5,603 Answers
First look for witness marks. SOMETIMES the length of the remaining wires will clue you where they came from.
Next look at the circuitry of the pedal switch. Can you see a common connection to all of the switches? If so, that MAY be a black colored wire or green or white.
ASSUMING you have three pedals, there should be 4 wires. There are exactly 24 possible connecting sequences. Bare the wires and short different pairs till you find the pair that do the sustain. One of those will be the common and the other the sustain.
NOTE: these are all low voltage connections so you should not get any electrical shocks.
Once you find two of the connections, the others become much easier.
Posted on Sep 25, 2009
Pedals stopped working.
If electronic trace the cable back to make sure connection is secure. Sometimes there is a button that turns sustain off, check control panel to make sure it is switched on. If piano is acoustic take off front panel beneath pedal board to make sure wooden rod is still connected.
Dec 24, 2013 | Music
Sustain pedal does not work on brand new Suzuki mini grand digital piano..... who fixes it
I have this same issue on my Suzuki S-350 Mini Digital Grande I got in Feb 2012 and I still have never fixed it. I'm still searching the internet for an answer. I figured if I could use the middle programmable pedal, that would suffice. But I've never figured out how to program the pedal! I've searched the menus and I can't find it anywhere! Even the manual doesn't show where this supposed menu is.
Oct 18, 2013 | Suzuki Promaster Harmonica, Key of A
I have a Casio CDP 200R. I recently purchased a FC4 foot pedal but it works in the reverse way. I tried switching the piano off and then plugging it in and it still does not work. Can you please let me...
You should try having the pedal connected when you turn unit on. Some pedals can be rewired to act opposite... However I believe this pedal should work with the Casio. You can open the pedal and see if you can move one wire so it works opposite. Also verify that the jack is set to the "SUS" setting per your user manual... around page E14
Sep 07, 2011 | Yamaha FC4 Piano Style Sustain Pedal
My yamaha ydp-160 sounds like my pedal is stuck down. All keys are sustaining all notes. Is there an easy fix?
On SOME Yamaha pianos, there is an electrolytic capacitor 1mfd/50v that becomes leaky and causes this. On those with the particular main board the capcitor is at location C94. On other pianos there are other caps that bypass the wire from the pedals that are ceramic. Likely one of these has shorted. There is also a possibility that the pedal contact has shorted. Test for this by unplugging the pedal cable. If it still sustains, then problem is internal. Unless you are adept at electronics this is NOT a DIY repair.
Aug 07, 2011 | Yamaha yDP S31 ARIUS Console Piano
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
I've got a Casio Privia (PX-400R) keyboard and it seems that the pedal jack has gone out. It's the 3 pedal jack circuit board. I took the keyboard apart almost completely to take a closer look at the jack...
Hi genoness1,
If you noticed that the pedal works on and off depending on the jack plug positioning, it is because the jack is already broken loose from the solder on the board. If the pedal that you are using can normally open as most or normally closed like Roland types, you can still replace the loosed jack. Unit has to be opened and correct jack replaced.
Hope it helps.
Thank you for using FixYa.
Apr 19, 2011 | Casio Privia PX3 88Key Portable Stage...
I have a Suzuki HP-97 electronic piano and the keys stick. What should I do to get them unstuck?
I called VMI Electronics and they sold me a repair kit called Key Mod, you can reach the company at: (619)244-0006 you can also orderer the repair kti through ebay: http://www.ebay.com/itm/Key-Mod-Piano-Rod-Replacement-Kit-/190822310728?pt=LH_DefaultDomain_0&hash=item2c6de56348
Jan 08, 2011 | Suzuki Music
I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Oct 05, 2009 | Roland Music
Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
The 'feet' my piano stands on broke during a move
Try www.yamaha24x7.com/yamahaoms/
Jun 20, 2009 | Music
Music Logo
87 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
