Question about Kenmore Washing Machines
My won't drain and just stop I tried to turn the nob to state the
My won't drain and just stop I tried to start the spin cycle by tuning the nob and manually start it and nothing happend
  • Kenmore Master
  • 7,482 Answers
Sounds like you have a broken belt, remove the cover on the back of the machine and check out the belt.
Posted on Sep 25, 2009
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
My washing machine won't finish its cycle?
try the reset again but turn the water off
Feb 25, 2012 | Zanussi Washing Machines
Fills up with water as normal but wont spin or drain. checked all house plumbing for blockages and height of drainage pipe as stated in instructions, gets to the spin section of program then all lights...
if its just not working on spin cycle, check the door safety switch, if its faulty the machine won't drain or spin,, you can jumper the wires that go to the switch , and set it for spin to see if thats the problem,
Jul 09, 2011 | Washing Machines
My washer will not spin or drain
most washers have a timer relay if it has started to go out this is one of the problems that can happen so check thie timer relay it is the big nob you turn to start your washer. Just so you know sometimes the relay cost more then a new washer but it's worth cecking out.
Feb 18, 2009 | Whirlpool Inglis IP4400 Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
WHen you start the washing machine. It starts to fill up than stops and all the buttons start to flash. then it stops after every cycle. then when it gets to the final cycle it freezes and I have to...
let check check first the DRAIN MOTOR PUMP it could be stuck with debri in the impellers , then check sensor switch located where you close the door , latch or magnetic switch ,it could be loose or damaged , then last the timer switch module , hope this helps AJ
May 23, 2008 | Frigidaire Washing Machines
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
24 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
