Question about Seiko Arctura SNL001 Wrist Watch
How much is the capacitor problem in Seiko SNL001 or similar model watches as I get to read reviews abt' capacitor problems appearing in Seiko kinetic watches after 3-4 years and the repair also happens to be costly?
    Scholar:
  • 110 Answers
Can be fixed in less than one week and cost is less than $80. See web site for Timelywatch repar.com. They guarantee their work. And yes, the old capacitors are only good for 3-4 years. All replacements are now with a much better, long lasting Lithium Ion battery.
Posted on Mar 07, 2010
Where can I find a review or description of seiko men’s 5N0313 dive watch ? I can’t find any
Seiko 5N0313 refers to the movement fitted inside the watch - it's not the model number of your particular watch.
Go to
https://www.leaf.tv/articles/how-to-find-a-seiko-model-number/
where there should be enough info' to allow you to determine the model number, then do a search based on that number.
Oct 17, 2017 | Seiko Watches
Model 48z8-g-1. What type of battery does it use?
You may have to open it up to find out.
Mar 22, 2016 | Seiko Watches
I do not know how to wind up my watch, while a swing to a later no.Please answer me.Model hours a Seiko Kinetic 5M62-0B40.Thank you
This watch operates on a capacitor which is charged by movement. It does not wind, but it has a weight that charges the capacitor by motion.
Take the watch in hand by placing your fingers under the caseback and your thumb on the crystal. Use a horizontal motion (landscape) to move the watch back and forth quickly approximately one foot left and right. You should feel the internal weight move.
Do this for at least five minutes. If the watch does not start to operate (the second hand does not move at one second increments) then either the capacitor must be replaced, or the movement is defective.
You may send the watch directly to Seiko for service, or I would strongly suggest visiting your local Certified Master Horologist for what is usually a free assessment and estimate of the repair.
If you are following the above directions, you have done nothing wrong, but the movement or capacitor needs to be replaced.
If you have just purchased this watch and the instructions do not resolve your situation, I would promptly return it and exchange it, as the model may have been sitting for a while, and have a bad capacitor.
Feb 23, 2011 | Seiko Kinetic watch
My seiko is keeping good time but the second hand jumps two seconds then hesitates for what seems to be a second then skips two seconds again
There are three solutions for this problem, contingent upon the model:
With both instances, this is a power saving / low charge / low battery feature of the timepiece.
1) Is your Seiko watch a Kinetic / Solar model? If so, your watch contains a capacitor. The capacitor may be bad, OR if you have not been wearing it on as regular a basis, wind the watch (Kinetic) vigorously for 5 minutes, and if the second hand returns to normal function, the capacitor is most likely fine. If is is a Solar model, expose it to sunlight for 4-6 hours or incandescent light for 24 hours and see if this resolves the problem.
2) Else: if this is a standard battery operated watch, take your watch to an authorized Seiko repair center, or Certified Master Horologist. Make sure that the Seiko Repair Center is using Seiko batteries, else make sure they are installing Energizer only - these two batteries will not leak in your movement. Avoid other batteries at all cost, many of them will leak and ruin your movement.
3). If these solutions do not work, and you have not had your watch serviced in the last 3 to 5 years, you need to service the movement. See the aforementioned parties to begin the process.
4) If your watch is water resistant, and/or you plan on wearing it in the water, make sure to have your watch water tested by the appropriate aforementioned professional to ensure it will withstand proper dynamic and static pressure at the appropriate depths.
Feb 04, 2011 | Watches
Seiko watch ser#687612,need a new battery,need to know which one
Hi there, can you look on the back of the watch for the model number. It should be similar to 7T62-0AC0 - I can then tell you which battery you require -
May 11, 2010 | Seiko SNA413 Wrist Watch
My watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
Oct 03, 2009 | Seiko Kinetic watch
Can I use an ordinary button cell in a seiko kinetic
I have been trained by a Master watch maker and I have worked on many Seiko Kinetic watches. Yes the original watches came with a capacitor that is charged by your arm movement. But unfortunately, they seem to only last a few years. All replacements are now done with a Lithium Ion battery that is much better and lasts longer than the original capacitor. This is the correct solution and don't try to use a battery type that is used in other quartz watches.
Oct 01, 2009 | Seiko Kinetic watch
My seiko kenetic watch stopped, and will not say wound
I thing required cleaning for the movement and new capacitor.
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 24, 2009 | Seiko Kinetic watch
Watch will not stay running
Most likely time to replace the capacitor with a new Lithium Ion battery. This is the correct way to fix this problem. No one uses the old capacitors any more. I do this repair daily as a Certified Master Horologist/watch repair man. Ron at TimelyWatchRepair.com
Dec 25, 2008 | Seiko Kinetic watch
Seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Seiko Arctura SNL001 Wrist Watch Logo
281 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
