Question about Cobra 18 WX ST 40-Channels Base CB Radio
My cb transmits with a very weak signal and won't recieve anything. The weather band recieves with no problems. I couldn't even pick up a signal on my SWR meter but a friend of mine tested it on his home station and got a small transmittion amount. He said he had a reciever on the other side of the room and he could hear himself talk but couldn't recieve anything either.
    Guru:
  • 773 Answers
There are a few things that could be wrong. If there is something wrong with the mic, you may not hear anything on the radio. but weather will work.
Other then that, the receive section of the radio could be blown.
Try a new mic, and if it doesn't work, then there is something blown in the radio. It needs a tech.
Posted on Oct 03, 2009
Just bought a connex coyote hunter.the antenna i have is for cb i know that for 10 meter radios you have to have a antenna thats tuned.on cb band shouldn't i be able to hear On cb band? With cb ant?
The antennae has to be tuned for the radio not for the band you are listening to. If is a 10 metre band, so you need a 10 metre antennae which enables you to listen to both bands, but looking at the jpg of the radio it gives bands A, B, C, and D, nothing about CB radio itself, but the option of AM and FM radio.. Using the wrong antennae could damage it.
you could get some help here
http://www.cbradiotalk.com/viewtopic.php?f=9&t=29531
specs here
Picture and Specifications of the Connex Connex Hunter Mobile Export Radio
Dec 12, 2015 | Connex Radio Communications
No transmit on usb.only recive but all works on am and lsb.1stGen.pres.whst
the transmitter section of the radio needs to be aligned you need to look for a cb shop its nothing you can fix on your own
Mar 28, 2014 | Radio Communications
I purchased a Midland 1001z in the fall of '09 and installed it on my boat. I is mated to the existing Shakespear 8' CB antenna. The CB worked great last summer while boating with my brother and...
Vibrations on the small cb's make the internal circuit boards come loose and its intermitted or will not RX or TX.. Check the antenna with another cb. using an SWR METER.. or have someone check it.. SWR should be free if you take it to them.. to check.. Make sure the antenna, mounts, and coax are ok.. if soo then its in the cb itself .. Email us if you need more help or need the radio looked at, the post office has flat rate boxes cheap nowadays. were in Temple, TX at the CB SHop.
May 30, 2011 | Midland 1001Z 40-Channels Base CB Radio
I have had my radio for a while and now just out of the blue the weather band stopped recieving or something, the rest works fine the wx led even lights up just no audio
If there is static noise, then it's probably not the weather board. We have had something like this happen in our area....
The closest weather station to here up and quit transmitting. The transmitter died after years of use. So all of a sudden there was not weather station. It was out for months.
If there is no noise at all, then there is probably something wrong with the weather board. I don't mess too much with weather boards my self. You could look at the weather channel selection knob and look and make sure all the wires are connected, also the switch to turn on weather.
Nov 10, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Realistic trc 443 cb quits transmitting and recieving
Sounds like the weather alert system is getting activated.
Jul 26, 2010 | Uniden PC78ELITE 40-Channels Base CB Radio
Can not hear anything
Take the cover off, hook the antenna up and turn the unit on. Take a pencil with the eraser end and press around on the circuit board, look for cold solder joints....hope this helps..
May 17, 2010 | Radio Communications
Have a new cobra 148 gtl took out of box no transmit or recieve
make sure that your [swr] hadn't changed or went higher than a 1.5, anything higher will interfere with your tranmitting an recieving. other than that with out being there to see an hear your radio this would be the first place to start.
Apr 25, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
I can recieve but i cannot transmit
sounds like you might have a bad voltage regulator
Apr 03, 2008 | Uniden Bearcat Pro PC68LTW 40-Channels...
Dx-88 HL
You'll need to take it to a repair shop. Because it transmits its under FCC rules so a certified tech needs to work on it.
Or take it back to where you got it and have them correct the problem.
Dec 29, 2007 | Galaxy Radios DX- 88HL Base CB Radio
Cobra 18 WX ST 40-Channels Base CB Radio Logo
929 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
