Question about Apple iPod nano
Ipod is locked, little lock signal on screen top left is on.
I treid the suggested solution to toggle the on/off switch, and press centre & menu simultaNIOUSLY, tried several times, cannot get it to unlock.
  • danie botha Dec 17, 2007
    I do not have the original computer any more it has been recycled. I tried my laptop, but no success. The thing is like a dead peice of wood. When you plug in the power it will charge. But refuse to do anthing else.
  • 119 Answers
Connect it to the computer you used to install it, and disconnect it again, it should be unlocked
Posted on Dec 16, 2007
  • Dick van Zalinge Dec 17, 2007
    If you can't unlock iPod using either [the code or
    connecting it to the computer you use to manage its songs]. . . you can
    restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
    If you want to change the primary computer that your iPod is associated with, do this:
    1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
    2. Connect your iPod to the computer that you want to be the primary computer.
    3. Open iTunes and synchronize.
Nano ipod will not charge and battery is low and on lock and wont disengage! help please.thanks
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
To reset an iPod with a Click Wheel: . Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Jul 11, 2010 | Audio Players & Recorders
Ipod locked
Make sure you have toggled the switch up at the top. If you see orange on top, flip the switch so that no orange shows. If that is fine, hold down the middle button and the menu button until you see the apple logo when you see the apple logo, continue to press and hold the middle button but press the pause/play button instead of the menu and it should unlock it.
Nov 06, 2009 | Apple Audio Players & Recorders
My ipods locked
Make sure your iPod is fully charged and then toggle the Hold switch on and off.
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2.Press and hold the Menu and Center (Select) buttons simultaneouslyuntil the Apple logo appears, about 6 to 10 seconds. You may need torepeat this step.
Jul 21, 2009 | Apple iPod nano
I need to unlock my ipod nano
for one make sure the lock button on the top of the ipod is slid to the left to unlock the ipod's buttons.
The default code for the screen lock is 0000 and if you are still having problems then reset it. with the instructions below.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jun 22, 2009 | Apple iPod nano
My screen is blank and nothing is working
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the
Apple logo appears.
Mar 15, 2009 | Apple iPod nano
IPod Nano 3rd Gen...click wheel seems to be frozen....
Hi, First find whether the Hold switch is in off hold position... ( Hold switch can be found at the botton or on the top of ipod) then try:
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Jan 13, 2009 | Apple iPod nano
Ipod has froze
have you guys tried a reset?
To reset your iPod:
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Aug 02, 2008 | Apple iPod nano
Ipod
Make sure the switch on top of the unit is in the unlock position. If it still isn't doing anything, press and hold the center button while holding down on the menu button. This will reboot your ipod.
Jul 26, 2008 | Apple iPod nano
Help
Make sure that your iPod’s hold button isn’t on. (little switch at the top left corner of the iPod). If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod screen. If you see either of these, move the switch back and see if this fixes the problem. If that doesn't fix it:
Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart it. You’ll know it's restarting when the Apple logo appears on-screen.
Jan 10, 2008 | Audio Players & Recorders
Nano Ipod won't turn off
Hi Debbie,
If your iPod is frozen , it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
You may be able to clear the problem by putting it in Disk mode:
  1. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons until the Apple/iPod logo appears, then release them. This resets iPod. When you reset iPod all your music and data files are saved, but some customized settings may be lost.
  3. When the Apple logo appears, immediately press and hold the Previous and Next buttons until the Disk Mode screen appears.
  4. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect
  5. Reset your Ipod.
Oct 13, 2007 | Apple iPod nano
Apple iPod nano Logo
46 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
