Question about Sony KP-51WS500 51" Rear Projection Television
Rear projection convergence out. replaced boards, blowing fuses
Contacted you about our convergence being out. We replaced the boards (Sony parts) still didn't work.(We are able to allign the blue lines with the green, but the red will only move vertically, we cannot move them left/right to adjust allignment.) Checked the pico fuses, which was what you suggested; one was blown. Replaced that, however that fuse blew again. We couldn't find 3.15a fuses anywhere, everyone we contacted only had 3a and said that should work. Do you think this is why the fuse blew or what else could be the problem? TV is a Sony kp51ws500.Thanks.
PS If there is anything much different we need to do in the tv service menu, please send detailed directions. That thing is like a maze!
(You mentioned earlier about sending an email for communication-how do I get that to you without everyone seeing it?)
  • 4,402 Answers
99% of these problems are due to either shorted pins or a missed pico fuse. The stk ic's are on the "D" board, attached to large heat sinks, When looking from the back you can see the heat sinks but the part's themselves will be pointing away from you and hard to see without removing the board, or using a mirror to look at the part numbers. The fuses are generally located under the fins of the heat sinks. There are several of them and vary by model. On the "G" board there will be two yellow pico fuses near the connector going to "D" board. These fuses provide power to the stk ic's you must check these as well.
Posted on Dec 20, 2007
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
Green projection light not alligning with red and blue. Flash focus will not bring them back. Sony Rear Projection KP-48S70
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
Note:The convergence/defletion/power board (the one the IC's are on) of this model is on the left hand side (when facing the back of set) also check for blown pico fuses when replacing the convergence IC's The best way to replace the IC's resistors and possibly fuses is to remove the entire board.
Oct 19, 2009 | Sony KP-48S70 48" Rear Projection...
Blowing fuses p50830bl
the board mounted overtop the of the chasis is the convergence power supply board
replace that board will bring your tv back to life
then go into menu readjust convergence red and blue DO NOT MOVE GREEN
Sep 01, 2009 | RCA P50830BL 50" Rear Projection...
Changed the ic's on my sony kp-65ws rear projection tv. (original parts) it fixed some of the bowing problems, and some the green and blue color problems. the red is still off and cant move the convergence...
did you check the two pico fuses on the G board. Usually the picos next to the ICs on the D board will be good, but the ones on the G board will blow when the original ICs failed.
Jul 12, 2009 | Sony KP-65WS500 65" Rear Projection...
Replaced STK's, fuses ok, +/- 22 VDC ok, still can
did you checke the two 5amp IC protectors located on the G board? Those will usually blow when the original ICs fail.
Jun 12, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP 51WS510 convergence problem
Please check pico fuses in D board and confirm +22 & -22 volt supply to convergence ICs.
Fuse numbers are as follows...
PS8001, PS8002, PS8003, PS8004, PS8005, PS8006
Dec 21, 2008 | Sony KP-51WS510 51" Rear Projection...
If you pull the D board and replace the ICs it will likely fix your problem. Check the input and feedback resistors with an ohm meter and see if they need replacing too. Sony has 6 output fuses that may blow with the ICs. If you replace all the bad parts, you can then magic focus to get back to a somewhat normal picture.
Dec 04, 2008 | Sony KP-57WS500 57" Rear Projection...
Convergence fuse Toshiba rear projection tv
Wire jumpers need re-soldering....Locations 008,010,017 etc
on inside edge of signal board near convergence IC's.....research
my Toshiba " H " Model rear projection " blows fuses" solutions.
Jan 27, 2008 | Toshiba 55H70 55" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
139 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
