Question about LG LRSC-26922 Side by Side Refrigerator
Lsc2690stt. we recently moved. we hooked up the water line and are able to get ice but water will not come out of the refrig. door. You can hear the water being dispensed but wont come out through the door. Any suggestions? This is model number LSC269oStt. Thanks
  • 489 Answers
SOURCE: ice maker
It is possible that the water valve behind the refrigerator is either defective or the wire connection is loose.  Also check the fill tube where the water comes in and see if there is ice blocking the fill tube.  Since it's under warranty, have it serviced by the LG warranty to resolve this issue.
Posted on May 11, 2008
  • 489 Answers
SOURCE: water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
Posted on Jun 08, 2008
  • 286 Answers
SOURCE: Do all ice maker refrigerators have filters on the water line
Most refrigerators dont have one, Usually you can install on in the supply line. If there was on it might be behind the frig
Posted on Jun 11, 2009
Joe Onley
  • 363 Answers
SOURCE: lg lsc26905tt ice maker makes ice, but wont turn dispenser
you can look to see if something from the freezer dropped into the chute? it may have blocked the exit. Is this all new ice or has it been a while since you used it? Maybe the auger in the bin is stuck?
Posted on Aug 27, 2009
omaharox
  • 165 Answers
SOURCE: We recently moved and hooked up the water/ice. It
Replace the icemaker.
If the ice maker mold is tan or silver they are defective.
Moisture gets into the head unit and jams the gears.
You can remove the icemaker and let it dethaw for a day and it might start working for awhile.
The new redesigned icemakers are brown in color.
Hopefully the switch on the side of the I/M is turned on..
Posted on Jan 09, 2010
Water not coming out from water dispenser
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the door line is frozen , GE has a heater which is easily installed , to keep this from happening again pt # WR49X10173
May 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Water dispenser not working,
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours so the heat will thaw the " hook " , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
May 15, 2010 | GE GSS20IEP Side by Side Refrigerator
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Mar 04, 2010 | GE Refrigerators
Water dispenser will not work Just tried to get water from the dispenser.I heard a clicking when I pushed the lever in with a glass,but no water.I loosened the water line at the compression fitting at...
The ice works off of a different solenoid than the water dispensor . So , I would suggest this action : At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Jan 28, 2010 | Hotpoint Refrigerators
No water is being dispensed from the water dispenser, but the Ice maker is working. Replaced the filter and still no water. When the dispenser is depressed, you can hear a humming noise but no water...
Start by : at the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . Ge also has a dispensor heater , pt # WR49X10173 , with instructions , to keep this freezing from happening again , if this is the problem .
Jan 20, 2010 | GE Refrigerators
Our water dispenser stopped working we can hear it click but water will not come out?
At the bottom of the freezer door ( remove the kick plate by removing 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If frozen , GE has a water dispensor heater , pt # WR49X10173 , to keep this from happening again . Also , by turning the dispensor light on , for several hours , so it will heat the spout , has worked for several people .
Dec 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Model gsl251grb water dispenser stopped working. r&r filter no help. turned temp down in case froze, no help. can hear motor run. ice maker works. help
Nov 13, 2009 | GE GSL25IFR Side by Side Refrigerator
GE sidebyside, I have no water coming out of the dispenser. I did change the filter. I can hear the water sensor come on/orr when I push the handle (dispenser that engages the ice/water).
If determining the water line is frozen , there is a water dispensor heater kit , which comes with installation instructions , pt # WR49X10173 .
Nov 09, 2009 | GE GSS25JEMWW Side by Side
Stopped dispensing water. Can hear a slight clicking noise from inside the freezer - but no water comes out.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . You can also install pt # WR49X10173 , which is a dispensor heater . This comes with instructions .
Nov 08, 2009 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
No Ice or Water
The water inlet solenoid valve orifice may be plugged. Locate the water solenoid valve where you connected the water line to. Shut off the water and then check this orifice and screen.
Apr 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
LG LRSC-26922 Side by Side Refrigerator Logo
65 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
