My duplicator does not read when i put a dvd in
My duplicator does not read when i put a dvd in it it just says copy 0mb
2 Suggested Answers
  • 114 Answers
SOURCE: Wytron DVD 319 duplicator not copying to bottom drive
has it just started to do it. have you tried a different make of disc. they do change the dye now and again.
let me know
Posted on Aug 01, 2009
Source Drive read disk error
The Cd you are trying to copy may be damaged, take it out clean it and try again, if that doesn't work check that the media you are trying to copy is compatible with the source discs, wouldn't be the first person to try copying a CD onto DVDs or vice versa, an easy mistake i've done this myself
Feb 09, 2013 | Acard Technology (ARS-2030LD) DVD±RW...
I have a stand alone dvd/cd duplicator at our church having trouble with. Cant copy onto dvd-r's. Master can be dvd-r or dvd-rw and will copy onto dvd-rw. when i try to copy onto dvd-r's, it will run for...
The two common problems, copier doesn't like color of discs etc, and slowing the speed that leave you've already tried. After those the most likely thing is that one of them has heads that are out of alignment. You could try copying cd's as they have coarser and the heads don't have to be as accurate. If that works then it is very likely it's the heads out of alignment. If they won't record on the cds at all it still can be the heads out of alignment too, but this test may help determine which drive is out of alignment.
Mar 06, 2011 | Computers & Internet
How do I use a 7 disk duplicator tower? Model 52X65x52x
Hi you put your dvd or cd into the top copier,put however many blanks you want copied into the burners below, you dont have to use all 7 if you dont want to make sure the control panal on the front says copy press enter and thats it.
Jan 24, 2011 | Tower CD&DVD Duplicator Cases: 8 Bays...
I have a Pioneer CD/DVD Duplicator 8 drives. Recently no matter what disc I put in as the master. It tells me I have a mad Master Disc. Obviously all the media can't be bad. When this messgae pops...
The 3rd drive is the master now. If you want to change back to top drive, go to #8 "select source" and use up/down key change to " drive 1 " and save. for more detail, please read the user manual page 21 and 22.
For VPD system,if the top drive defected, the system should auto assign 2nd drive as source, but your system pick up 3rd drive as source drive, I suggest you check drive 1 and 2 before make copy.
Jan 04, 2011 | Pioneer 1 to 7 DVD Duplicator: SharkCopier...
Machine won't duplicate CD or DVD...A good disk is in source disk area but it reads Source Disk empty or Source Disk not ready....
The solution to this is simple. On the menu when you see that the # of MB is 0MB. Press the Arrows that change the menu option to #8 Select Source. Change this back to your original DVD-Rom or RW drive.
Nov 07, 2009 | Computers & Internet
Cannot copy dvds or cds with my duplicator
Hey! Usually, DVDs have some protections which prevent DVD users copying DVDs freely. Theser protections include CSS protection, region code protection etc. Therefore, you need to remove DVD protections first if you want to copy DVDs. There are some DVD Copy software which can do this. I have a good luck with this DVD Copy which works fine. You can have a try if you like.
Hope that helps.
Nov 07, 2009 | Plextor Dupsonic 52X 1 to 9 CD Duplicator...
When trying to copy a CD, I get the following error message: Warning - Bad Master Disc!
I assume it means just what it says. The Disc you are trying to copy is faulty?
Clarify what you are trying to copy. If it is copy protected, A duplicator wont copy it. Or the disc was made in a format incompatible with the master drive you are using. Ive had drives read some discs and another drive that cant read the same disc. Some brands of discs work better on certain drives. Try to use top quality reccomended discs such as Verbatim.
Char S.
May 27, 2009 | LG 1 to 6 Target CD Duplicator 52x CDRW...
Targer drive not ready.
"Target overflow" just means that the disc being used to make the copy doesn't match in size. "4.7GB" to the master disc. Sometimes this occurs when you make a mistake thinking the disc in the copy slot is a DVD blank but it may be a CD-R blank(by accident) or sometimes the Master disc is a BD-R and trying to copy to a regular DVD-R (won't fit)
"Source drive not ready" is when the Master disc keeps spinning in the attempt to read. The "culprit" alot of times is the brand, or scratched, dirty, corrupted discs.
Make a copy of the master again (if possible and on your PC with a different brand of disc) then use the new Master to make the multi-discs you want.
"Target drive not ready"
is when a disc with information already on it, is in the copier (can't copy over it) sometimes we make mistakes and put the Master in the copier and vice versa : )
or no disc in it at all, and or some sort of incompatible blank media.
I have a 7 disc duplicator by Pioneer and I found that in the last few years since I've had it (since 2005)
I ran into the above situations alot.
I use it as a standalone (not hooked up to any PC etc)
It still works great but I find that was having a brand name issue with the discs; certain discs that it used to read in the Master/Source drive like Taiyo Yuden, Memorex, Ridata, SKMAX, and Phillips, suddenly don't want to read properly when inserted. The discs keeps spinning and then when you press "copy" it says "Target overflow" or "Source drive not ready" I found that solution I mentioned above with the changing of the disc brand helps fix the situation. I didn't want to hurt my brain trying to figure out what it could be as I use my duplicator for business and time is money.
Through trial and error I end up just making duplicates from my PC on different brands (cheaper unknown brands work fine) and then using the "new master" made from these is the only way I can duplicate..weird!
P.S sometimes the lens may need an old fashioned cleaning with a lens cleaner or Dust blower.
Once in a while one or two of the doors get stuck even when all 7 discs are completed...just take a q-tip with vaseline and put it on the track wheel for some lubrication and the door will open up easier.
Just some tips from someone who's had their player a long time
Hope this helps anyone in need out : )
Jun 20, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
Teac 1x1 dvd duplicator dvw-d11
This seems to be a memory/cache problem - increase (double) your cache size .....
Mar 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
