Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
It is a Total Hayward System. The thermostat and, control box, freeze protection unit is located in my back yard behind a fence. When you say the thermostat is probably malfunctioning, do you mean the freeze protection switch? If so, would i need to change that part?
  • 990 Answers
It is hard to say with very little information in your problem. But if your having problems with a temp control of any kind and things run but not at the right time the first place to look is your temp sensor. this is a cilinder usually copper or stanless steel about half the size of a ciggeret and a little smaller around with two wires coming out of the end of it. If it reads water it will be inside a pipe and you just have to follow the wires. If it is a air sensor it will probally be just below the control box and ether hanging free or mounted to the wall, but it should be in the shade. If this is on a heater it will be found inside the unit usually on the main water header.
Posted on Nov 04, 2009
Pro-Logic Pool Control Panel says freeze protection deactivated but I didn't turn it off. Expect 2-3 days below freezing and I have to get it back on to avoid damage to the pump. Please help
go into system setup activate freeze protection it will then ask you which features you want filter pump jet pumps make sure if you have water features and a autocover cover is open or those are not freeze protected
Dec 06, 2013 | Hayward Pool & Spa
I need some kind of fence with at least 1 gate. I have vinyl fencing on both sides in the back yard, but it's only privacy fencing to separate the yards. I have 2 small dogs and I can't let them out i
You could probably continue the vinyl fencing but that will cost a lot. You could always use a chain link fence which is really cheap and easy to install but it won't look right.
Aug 08, 2013 | Sport & Outdoor - Others
Samsung side by side fride
The first thing I would check is that the condenser grill under your unit is clean and the air flow is not blocked (also that the lower fan is blowing air across the coils. Even if that is not the total cause it will help your unit operate more effeciently. The condenser grill is under your unit accessed by taking off the front kick panel and also through the rear.
The second thing I would check is for ice build up around the evaporator coil (located in the back of the freezer section). If there is ice build up then you probably have a defrost system failure. This circuit is made up of the defrost heater, defrost thermostat (both located in the freezer section close to the evaporator coil) and the defrost timer which is located in the fresh food side (or if newer frig, part of the control board)
Jan 06, 2012 | Samsung RS2630SH Side by Side Refrigerator
Code c776 on a rheem tankless hot water heater. How do I disconect the remote and let water heaterdefault to 120 degrees??? I have the UMC-117 remote. Also any way to put a thermostat on this thing to...
The remote is hardwired to the tankless unit.
Turn power off. Open front cover, and locate wire connections and disconnect. Turn power back on. Open hot tap and see if unit works at 120 degrees F default temperature. If not, then problem can be PC board.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Typical schematic showing remote controller connection:
http://waterheatertimer.org/images/Tankless-wiring-1200.jpg
Some tankless units have built-in freeze protection.
I live in Texas and did following to protect my outdoor water heater: Thermostat controlled heat tape around pipes, and build a box around water heater out of styrafoam, and then put light bulb inside styrafoam box. I hooked up 120Volt mechanical thermostat to light bulb circuit.
Open following links for error codes, typical manuals, Rheem contact phone and chat, plus regular maintenance manual:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 27, 2011 | Home
I have just replaced the thermostat in my mitsubishi outlander 2006 zf 2.4l auto wagon and I am flushing the radiator but i need to know the coolant/radiator capacity and the ratio of coolant/water
Hello aislin87,
The total engine coolant capacity is 7.4 quarts.
Just changing the thermostat should not drain the entire system so you wont need that much.
The recommendation is above 30% but below 60% anti freeze to water to provide for proper freeze and anti-corrosion protection.
Regards,
netvan
Feb 27, 2011 | 2006 Mitsubishi Outlander
I need only the thermostat part of unit pf1202t. Please advise plus price.
1) Smarthome sells for $80
Double check model numbers
http://www.smarthome.com/42699/Intermatic-PF1103M-120-240V-Freeze-Protection-Control-Timer-Mechanism/p.aspx
2) Google search for: Intermatic freeze protection thermostat
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | Intermatic Timer PF1202T Multi Circuit...
Fusebox location
Relay Center Cooling Fan Controller
  • Located behind the left side of the instrument panel.
Cooling Fan Controller Module
  • Located behind the right side of the instrument panel.
Cooling Fan Relay
  • Located in the air conditioning cooling fan control module.
Electronic Control Assembly
  • Located under the left side of the instrument panel.
Electronic Engine Control Power Relay
  • Located behind the glove box on the right side of the instrument panel.
Fuel Pump Relay
  • Located behind the glove box.
Horn Relay
  • Located in the fuse block.
Let me know if this helps. If not, let me know.
Circuit Protection The fuse panel is located below and to the left of the steering column.
Fuses are a one-time circuit protection. If a circuit is overloaded or shorts, the fuse will blow thus protecting the circuit. A fuse will continue to blow until the circuit is repaired.
Main fuse box located on driver's side to the left of the steering wheel, above the brake pedal.
Aug 07, 2010 | 1991 Ford Tempo 4 Door
Hayward Pool Freeze Protection Switch
Yes their is a temp sensor or thermal bulb depending on the unit.
Sep 25, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
48 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
