Question about LG enV VX9900 Cellular Phone
My sister threw me my phone and i missed it and it hit the floor
Then when i tried to use my phone it just said battery is required
Remote does not work
easy way to check remotes if there working, is to use the camera on your phone and point the remote at the phone and hit some buttons, you will see the invisible UV light the remote uses threw your phone.
If no light is seen might be a battery or battery contact issue, try spinning the battery's while doing the test... KOOL huh
Jay the pool pump motor repair guy in longwood Florida
remember to thumbs up. thanks.. J
Feb 08, 2014 | Samsung PN59D6500 3D Plasma TV
I miss pssword
my sister password missing
Sep 20, 2013 | Nokia 3110 Cellular Phone
I have a dead battery in my lg envy and my charger wont charge my phone but that same charger will charger my sisters phone. How can i get my phone to charge?
try your sisters battery on your mobile. if it powers up and your charger isnt working on your mobile then you have an internal loop fault in the power section of the mobile that directs power to charge the battery. its a big fault and is far cheaper to replace the phone than to have it repaired.
sorry
take care.
Aug 03, 2010 | LG enV VX9900 Cellular Phone
My 2 year old sister threw my kyocera X-tc phone in the pool 3 days ago. The first thing I did was dry it off and take the battery out, I dried the battery and the phone again, and put the battery in. I...
Hello, There is still water inside the phone that's why some part are still working and some not working yet.
What to do is this,
Unscrew the phone,
Get a Methylated spirit and a brush,
Bring out the board of the phone and use the methylated spirit to brush off remaining water on phone.
Keep under heat to dry off,
After board is dried, fix it back and screw back phone.
Am sure after doing this phone will work well.
But if phone still doesn't work ,that means water has damage some component inside the phone.
You will need to consult a phone technician for assistance.
Take care.
Jul 03, 2010 | Kyocera X-tc Cell Phone
Partial Display Screen Damage
The screen will keep malfunctioning since it fell and its display is half top the screen. is the phone slide? if it is, it is the flex on the phone screen that will need to be change. but if it did not solve the problem, then,
I advice you get a brand new screen for replacement and when going to get the screen, please go with the phone so that you can get the exact screen and a working screen.
Regards
Apr 25, 2010 | Samsung Star GT-S5233 Cell Phone
The LG washer vibrates so much that it shakes the dryer. They tell me that it's the hardwood floor, but it's still too much vibration.
If the washer is solid on the floor, and the floor or walls are vibrating, it's a weak floor. This is our biggest problem with most front loaders. Beef up your floor by installing blocking between the floor joists, install another pier, or sister the joists, check on the internet for how to sister joists. Good Luck, Appliance Specialists
Jan 03, 2010 | LG WM-2277HW Front Load Washer
Not able to send/receive text
hi
try contacting your network sim operator and ask them to send you the text / mms numbers settings to your phone sounds like they are missing this can cause texts and mms to not be sent recieved
riz.
Jan 17, 2009 | Motorola Mobility KRZR K1m Cellular Phone
89 s10 blazer help
have someone check the starter/solenoid
Jul 27, 2008 | 1989 Chevrolet S-10 Blazer
LG enV VX9900 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
