Question about Brother LS-2125 Mechanical Sewing Machine
I have a BS-2145...no idea how old it is but cannot download an instruction manual for it and do not know how to run a bobbin, can you help please?
How do i thread the bobbin on simplicity fashion pro sw 2145
normally counter clock wise for bobbin, usually the first thread holder is used and the 2nd is used for double needles. here is a link for parts
Simplicity SW2145 Parts
Dec 06, 2014 | Simplicity Fashion Pro SW2145 Mechanical...
Bobbin problems winding
Does the bobbin winder have a rubber o ring on it so that when the winder is in the winder position are the two making contact to wind
Mar 14, 2014 | Sewing Machines
How do I load bobbin
Go to http://www.singerco.com/accessories/instruction-manuals/search and enter "9940." You can download the manual for free for the machine, which should tell you exactly how to load the bobbin.
It's a good idea to have the user's manual, anyways, and the downloaded one is more complete than the printed one of Singer's manuals in any case.
Jun 09, 2011 | Singer Quantum 9940 Computerized Sewing...
I gave taken out the bobbin casing because my needle would stick & looping in the bobbin stitch. Now I can't get the bobbin casing back in. Help! Please
Take a look at your manual, and on page 25 there is a pretty good picture of the bobbin case assembly, look at with a magnifying glass and it helps. If, you cannot find your manual, go to www.singerco.com and under customer support, click instruction manuals, enter 1418, now download your manual for free. Then save it to your computer, and you can enlarge the diagrams for easier viewing. It is a good idea to download it and save anyway, because then you cannot misplace it. Good luck
Dec 30, 2010 | White Sewing 1418 Mechanical Sewing...
Bobbin questions
You can download the manual here. If not the right one please give model # and I will get you the right one.
http://www.singerco.com/accessories/manuals.html
Good luck and Please rate
Sep 18, 2009 | Singer 7442 Mechanical Sewing Machine
Old sewing machine, no owners manual
I got the same machine when I was 12 years old and still use it today. Try adjusting the tension - it's the know with number 0-9. To decrease tension turn it to the left. To increase tension turn it to the right.
On the side of the bobbin case is a screw that also can be turned with a small screw driver to increase or decrease tension the same way as mentioned above.
If you send an email to me at rhonda_1961@yahoo.com I can see about getting a copy of the manual to you. It doesn't have the cover but everything else is there.
Aug 18, 2009 | Brother LS-2125 Mechanical Sewing Machine
I need a copy of the instruction manual for the Sew Smart Compact Cordless 17390B.
If pictures are helpful, take a look here
This is for a front loading bobbin
You have not mentioned the machine or model, so if this is not like yours, it will be a top loading or drop-in bobbin.
In either event, the idea is to pass the thread thru a small slot and thereby between a tensioning spring......your Instruction manual will have details for your model, tho' with a little thought, any manual for a similar machine (top or front loading) should give you the basic idea.
If you still have troubles, let us know the make & model.
Feb 09, 2008 | Sew Smart Compact Cordless 17390B Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
295 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
