Wifi connection problem
After having connection with home wifi attempted to utilize a phone as a modem (blackjack) settings were changed now am not able to reconnect my vltop to my home system if this would be better over a phone line let me know please. am in a rush to attain this connection have a million things to do for the holidays Please are you able to help ? Thanks for the quick response.
  • 12,061 Answers
Use the network connection wizard to remake ya connection. Re-setup your internet connection again, with the wizard enter all relevant info ya should be good to go?
Posted on Feb 08, 2008
How do I connect to WiFi in my home
You Wifi has a name and an address. On your phone, go to settings and wifi. It should tell you what wifi signals are available. choose yours and it will probably ask you for a password. If you know it, put it in. If you don't know a password name, look for the one that came with your modem, it is written on a tag on the modem.
Oct 06, 2017 | Cell Phones
Hp a345w desktop pc dcs server not found conflict
what OS, we can NOT GUESS your operating system.
so where are you , home or star bucks.?
what is your connection, wifi, ethernet, or others?
a desktop pc can have vast ways to get internet.
1: modem dial up (i bet not this, nobody uses this now, 99.9)
2: cable modem, sat modem, fiber modem to ISP
3: USB wifi dongle, on PC and to local router.
4: PCI card wifi. , to router.
5: ethernet wired to router or modem direct. a cable wire. CAT5/6
one can even have direct wired ethernet to the cable modem
or you might have wired to wifi router (2 ways to connect there)
NO OS stated
no connections stated.
my guess is DCS, means DHCP not found, or DNS not found.
lots of causes, but I will not attempt to answer for all 6 ways.
May 30, 2017 | HP Computers & Internet
My printer will not fax says not connected to network when it is.
faxing requires some type of Phone connection in most instances, network faxing is another set of drivers that need to run on your PC, the same as phone line faxing that utilizes your modem (as long as the modem is fax capable) the issue you have is the way it is set up. first off you have to have the communications between the printer and the computer running properly. If you do not have a router with a wifi connection and the printer is connecting directly to the computer wirelessly, you need to make sure it is set for peer to peer networking, if you have a true network using a router and wifi (more than one computer can connect to it, you need to make sure you are set for that. Remember, you are not faxing from the printer if it is not connected to a phone line, you are faxing from your computer. and you need to make sure you are running the correct type of fax software, for network faxing or dial up (phone line) faxing.
Jan 21, 2015 | HP Photosmart 7510 e-All-in-One -...
Unable to connect to the Internet Confirm the Internet settings of the wii console. Error code 50299.
Go to internet options on your Wii settings, select internet, and then connection settings. Once that is done you will be able to see the wifi connection. Click the wifi connection and delete it. Try to reconnect the Wii to your wifi router and you should have success connecting to the internet. If it doesn't connect repeat the steps listed above.
Dec 31, 2014 | Nintendo Wii Console
Iphone 4s no network coverage at home
By no network coverage do you mean no cellular signal or can't connect to your home wifi? If wifi trouble push settings button on iphone. Select and turn on wifi. It will search for available wireless networks. Choose your home wifi, should be the strongest signal, most bars. If you don't know your ssid , look on the sticker on the modem. For instance ssid at&t 2345. Once you select your ssid you need to enter password which is also found on the sticker on modem. Enter password and select join. You should now be connected to your wifi. This will always reconnect automatically when you leave and come back home. If not wifi issue, are you just too far from cell tower to get good signal?
Sep 06, 2014 | Apple iPhone Smartphone
Why has my mobile phone WiFi stopped working at home?
Open your wifi on the phone and press and hold the wifi network that you want to connect to then click (modify) re-enter the security code for the wifi network again and then connect. If that does not work then the wifi signal is weak and you'll need to get closer to your router.
Another thing is to choose United States for your Wifi Region in the wifi advanced settings menu.
-- uncheck (avoid poor connections)
-- check scanning always available
-- Wifi Region Code (select United States)
I hope that helps
Jun 11, 2014 | HTC Cell Phones
S3653w dns failed
  • 1. Delete the configured wireless connection if you already have one
  • 2. Enable WiFi but do not perform a search at the moment
  • 3. Open the browser, select Settings > Browser profiles and press "Search for WiFi"
  • 4. Select the connection that you want to connect to and type the details that match the settings on the router
    • Auth type = WPA
    • Encryption = TKIP
    • Network key = router pre-shared key
    • Protocol = HTTP
    • Home URL = address of modem (you can change it later if everything is already working)
    • Leave proxy blank
    • Linger = default
    • Adhoc = off
    • There is no need to change the advanced settings
  • 5. Save the settings but do not connect yet
  • 6. Exit the browser, go to WiFi and select the connection that you have just configured
  • 7. Check all the settings are OK
    • If the channel is different to the one set on the router, adjust it on the router to match the one used by the phone
  • 8. Activate the selected connection and try browsing the internet
That should get everything working. This applies only to personal wireless networks.
Nov 15, 2013 | Samsung Lands Phones
Hey when i am connecting samsung gt s3310 to pc then in pc it showz modem driver not installed
Its trying to connect your phone as a modem, which is pretty much useless now unless you have a dial-up internet account. If you want to use you phones 3G or 4G connection, you should connect you phone via WIFI to you computer and use the phones software to share your internet connection to WIFI.
Jul 31, 2011 | Samsung Modem Configuration Software...
Im connecting to my home WI fi and it says authentication failed
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
Sep 12, 2009 | Samsung Jet S8000 Cell Phone
Computers & Internet Logo
165 people viewed this question
David Payne
David Payne
