Question about Dell Dimension 3100 PC Desktop
My XP platform is running "mscorsvw **exe " and using 94% of my CPU per the task manager. How do I resolve this?
    Problem Solver:
  • 7 Answers
Try going to advanced hardware settings and expaand your V-RAM (vertual random access memory)
Posted on Sep 25, 2009
I have a computer [AMD athlon(tm)]xp 1800+ 1.50 GHz]. My problem is when I switch on the system,the OS will open and i don't open any application then if i see in 'Task Manager - performance' there the...
Type "msconfig" on search bar there will be bar "startup apps" click that and click on disable all and restart your system...hope it works... Regards: imran
Sep 19, 2014 | Computers & Internet
Tip
How to Enable Task Manager in Windows XP
Method 1
  • Click Start, Run and type Regedit.exe
  • Navigate to the following branch:
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  • In the right-pane, delete the value named DisableTaskMgr
  • Close Regedit.exe
Method 2: Using Group Policy Editor - for Windows XP Professional
  • Click Start, Run, type gpedit.msc and click OK.
  • Navigate to this branch:
User Configuration / Administrative Templates / System / Ctrl+Alt+Delete Options / Remove Task Manager
  • Double-click the Remove Task Manager option.
  • Set the policy to Not Configured.
on Dec 08, 2009 | Computers & Internet
ROOT\LEGACY_QKNFD\0000
To resolve this issue, examine the device manager to see whether the .NET Runtime Optimization Service V2.0.Number_Numberis installed as a device. If the service is installed as a device, you must uninstall the device. Then, run the following command to install the service correctly:mscorsvw.exe -i
To do this, follow these steps:
  1. Click Start, click Run, type DEVMGMT.MSC, and then click OK.
  2. Right-click .NET Runtime Optimization Service V2.0.Number_Number if the device appears, and then click Uninstall.
  3. In the Confirm Device Removal dialog box, click OK.
  4. At the command prompt, run the following command:%WINDIR%\Microsoft.NET\Framework<64>\v2.0.Number\mscorsvw.exe -i
Jul 18, 2014 | Microsoft Windows 7 Home Premium 64BIT...
CPU = 1 processors detected. Cores per processor = 2 Genuine Intel(R) CPU T2060@60GHZ 2639 system RAM passed. 1024k Cache SRAM passed. system BIOS shadowed video BIOS shadowed
if you are referring to the detected processor in the task manager, open task manager and click the VIEW menu, then select One Graph Per Processor. Another thing to do is to go to START, then click RUN, type MSCONFIG and click OK. Once you have the MS CONFIG window up, click the BOOT tab, click ADVANCED OPIONS. From there, select/check the Number Of Processors box, then select 2. Click OK, then APPLY/OK. Restart the computer and confirm if that resolved the issue. Hope this works. Feel free to rate how useful the info is.
Nov 15, 2010 | Computers & Internet
Windows did not appeared, only mousepointer was appeared. The icons on destop, taskbar and start menu are not appeared. What are the best solutions Tank you!
Press Ctrl + Alt + Delete together and Task manager will be opened. Click on file -> New task . In the box type explorer.exe.a nd click ok. If this doesn't works boot your computer from XP disk and run repair from disk.
May 27, 2010 | Microsoft Windows XP Professional SP2
Why is my cpu constantly running at 100% and my fan constantly running no matter what I do?
it is kind of known issues with vista OS.
Press ALT+Ctrl+Esc or go to task manager -> process-> you will get which process is taking much CPU usages.
Then right click on the particular process and delete it.
This happens most of the time because of the SVHOST.exe
To get rid from it.
Check one of the below solution provided on the forum. This should resolve your issue.
If not then please get back with the screenshot of the task manager process window. So we can determine which process is consuming the max usages of CPU.
http://www.zolved.com/synapse/view_content/23054/Windows_Vista_-_Troubleshooting_Excessive_CPU_usage.
Dreamkam
May 17, 2010 | HP Presario CQ60-211DX (NB049UAR) PC...
My aspire is installed with windows xp no drivers but CPU running
Within TASK MANAGER, click the "Processes" tab.
Click the 'CPU' column-heading.
Click it a second time.
Now, each process will be listed in order,
with the TOP-MOST lines showing the processes that are consuming the largest share of the CPU.
Nov 06, 2009 | Acer Aspire 3050-1733 Notebook
Task manager disable
ur computer is viral infected log in in safe mode and remove norten load avast home edition 4 free avilable on avat site to use folder option again u have to install new window
Mar 22, 2008 | Microsoft Windows XP Professional With...
Hide task manager
hi dear
start menu, run
type regedit
find this....
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
change dword to 000000000
oke
Mar 19, 2008 | Microsoft Windows XP Professional
Dell Dimension 3100 PC Desktop Logo
70 people viewed this question
Alun Cox
