Question about Stanley Bostitch MIIIFN Flooring Nailers
Using the BOstitch flooring nailer, good air pressure and using cleats. but when i tap with hammer noting happens. the nailer goes off as if it had gone off but no nail was driven.
    Problem Solver:
  • 10 Answers
1. check to make sure the magazine does not contain a jam.
2. check to make sure the driver retracts fully to allow the cleat to advance
3. Be sure to have at least 90psi and to hit the head hard enough to fully fire the nailer.
Posted on Oct 31, 2009
My bostitch 201 manual floor nailer is stuck with cylinder in the down position. Brand new refurbished, about 50 2" cleats driven without a problem, then some sort of misfire resulting in the stuck...
Could be bent driver or debris. Easy to check. Remove air supply and nails. Remove the four bolts holding bottom of nailer together. Make note of how the pieces are assembled. Set bottom parts to side move piston in and out of the cylinder. Should be fairly easy to move but should not drop out of cylinder of its own weight. Next insert driver into nose to check for smooth fit. Bent driver should be obvious and can be straightened. If driver looks good, find and remove debris from nose of gun. Good luck with your flooring projects Order spare parts kit to have on hand because drivers will break and bend and the lower bumper will begin to break-up.
Aug 06, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
Nail cleats are not exiting when the mallet hits on my Bostitch MFN-201. The spring mechanism appears quite loose; you can push it down or in very easily by hand.
That is most likely what needs to be replaced as that is the return spring. If it is weak it may not be allowing the driver to go back up far enough to let the next cleat load into the nose. Here is the parts diagram. Bostitch (Stanley Tool Works) just merged with DeWalt so you can get the part from either company now or a dealer of either company.
http://servicenet.dewalt.com/Products/Detail/MFN-201
Jul 23, 2011 | Stanley Bostitch Mfn201 Manual Hardwood...
My Bostitch MIII floor stapler is not driving staples. I partially drove one staple with a glancing blow then drove another on top. I cleared the jam and now it will not feed staples; It fires...
Slight damage to driver will prevent it from returning to top of cylinder (assuming that nailer worked correctly before double fire). Easy to check. Remove airline. Use metal or plastic to push driver to top of cylinder (should easily move). After the driver is at top, see if first cleat moved into proper positon. If cleat is not in position, check pusher and rails for debris. If cleat is in position, activate nailer to check for proper function. If driver does not return to top of cylinder and was difficult to push up, pull out driver and check for bent /damaged driver and replace orings and lower bumper while apart if parts look worn. Good luck
Jul 13, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
Nail won't set to allow tongue to enter groove
Your nailer has variable sized plates /shoes bolted to the bottom. I believe that there are about three different thickness available. Take a look at the link below for a parts list showing the sizes available. For a quick fix to drive the cleat deeper, use a thinner bumper below the head of where you strike the nailer. If you manually push down the striker, you can see how much of the driver comes out the bottom. The bumper below the head (black rubber washer) cushions the striker against the body of the nailer. A thinner bumper (you must be creative here) will allow the driver to extend out slightly more. Good luck with your flooring projects.
nailer-parts-c-29443_29458_29679.html">http://www.ereplacementparts.com/bostitch-mfn201-flooring-nailer-parts-c-29443_29458_29679.html
May 30, 2011 | Stanley Bostitch MFN201 Factory...
My MFN-201 cleat driver will not drive the cleats deep enough into the 3/4 inch prefinished bruce flooring. It postitions the cleats fine. It is on the Rachet setting.
There is a piece of rubber under the head called the bumper. This rubber piece is what stops the driver from forward travel. If you remove this rubber or replace with thinner, you can drive nail deeper. Most likely your driver blade may be worn or where driver blade attaches to shaft may be worn. Tool would need to be disassembled to check. Parts are not expensive and available at www.bostitch.com Good luck
Apr 06, 2011 | Stanley Bostitch Mfn201 Manual Hardwood...
What is the correct way to place the nails into the gun? This gun uses both cleats and staples. I am using cleats but it does not seem to be working. I may be putting the cleats in wrong.
If you have a Bostitch MIII FN it is only for cleats. Bostitch doesn't make a universal nailer that takes staples and cleats. The MIIIFN is the "floor nailer" and the Model MIIIFS is the "floor stapler"
Maybe check exactly what model you have and ensure you are not trying to put cleats into a stapler.
Oct 17, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
Can u use a m3 model to nailer 3/8 flooring
yes, you need to shim up the plate of the nailer so the cleat goes thru the "v" of the top of the tounge
May 24, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
I am using a Bostitch MFN200 Manual Flooring Nailer and we are having some trouble with it. The cleats go almost all the way into the floor board but are still sticking up about an inch out of the board....
2 things come to mind. I've installed Wood Floors for the last 5 years.
Make sure you have enough Air pressure running to the stapler,
and Second, Whack the hell out of it. You can be rough with it. Their designed to take a beating
When u hit it with the mallet, youre opening a valve which shoots the piston and drives the staple into the boards. hit it not hard enough, not enough air is being sent to the piston to drive it fully.
Aug 02, 2009 | Stanley Bostitch Industrial Manual...
5/8 flooring nailer
the base plate may be shimmed, but that unit was designed for 1/2" and 3/4" however, the Bostitch MFN201 Manual Flooring Cleat Nailer Kit will install 1/2"- 5/8" & 3/4"
Feb 17, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Stanley Bostitch MIIIFN Flooring Nailers Logo
456 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
