Question about Toshiba 50H72 50" Rear Projection Television
Toshiba projection tv 50 inch
The tv turn but no sound no picture it is a 1997
  • etgchange Jul 06, 2008
    Hi
    I have a Toshiba 50H72 and it was fine with no problems. Next day you could turn the TV on and the red power light goes on but no picture and no sound. Checked the PD0074 deflector board and found fuses F850 and F851 blown. I replaced them and again they blew.
    Any ideas of what is wrong?
    thanks, Ed
I have TOSHIBA PROJECTION TV MODEL TZ50V51. While it was on all of a sudden it wnet blank. When you power, the red light lits and starts blikning with nothing coming on. Help please
Posted on Oct 03, 2008
  • 934 Answers
Need to test F470 and F850 for open.. Simple continuity to see if either fuse is open.. If F 470 is open replace it and C884 and if F850 is open you probably you may need to replace the two convergence amps STK392-110... Large black Ic's screwed on an aluminum heat sink...
Bill
Posted on Feb 03, 2008
3 Suggested Answers
  • 579 Answers
SOURCE: toshiba projection tv 50 inch
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Posted on Jan 07, 2008
Maciso
  • 125 Answers
SOURCE: No sound
make sure the external speakers are not turned off
Posted on Aug 23, 2008
Turned itself off. I turned it back on and the green power light blinks for awhile then blinks red for awhile.no picture or sound
Get rid of this TV. Had one and replaced the bulb and light engine many times. Just buy a Samsung or Vizio 50+ inch instead and be very happy. Those Panasonic projection TV's were terrible. You will find a 50 inch Vizio for around $500 bucks and it will blow your mind how great the picture looks.
Oct 16, 2014 | Panasonic PT-50LC14 50" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a toshiba 32 inch 1997 tv. When I turn32G90 it
It sounds like the picture tube may be weak (because it's orange) but it going to half ascreen is not caused by the picture tube but likely a vertical circuit problem. If this problem happened suddenly (going orange) then the picture tube is probably good and at least worth bringing in for an estimate.
Oct 06, 2009 | Televison & Video
I got a 50 inch TV and I cought my daughter banging on the TV screen and now there's no picture but the sound is good, please help
it damaged the crystals in the LCD Panel the only way to fix it to take it back to where u bought it and tell them the screen went out they more than likely will replace it
Sep 01, 2009 | Toshiba 50H82 50" Rear Projection...
Why does my toshiba 72 inch projection tv picture freeze?
sounds like your dmd module. its the part of your optical block that processes the images that make up what is projected on your screen.. without a model # i can't tell you the part #
Mar 13, 2009 | LG Televison & Video
Toshiba Rear Projection TV Problem
common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Sep 15, 2008 | Toshiba TZ50V51 50" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
No sound
Apr 28, 2008 | Toshiba TZ50V51 50" Rear Projection...
1997 Toshiba 50 inch tv
Sounds as though you have a filter capacitor bad in the power supply. I strongly suggest you have it checked and repaired soon, before it burns up a transistor or regulator. The cost may be a bit high now, but will escalate to possibly a complete power supply board. If you can repair your own set, check the main power supply filter capacitors. Good luck. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Toshiba TP50G50 50" Rear Projection...
Hope Ya Fix it!
Jan 07, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
254 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
