Question about Water Heaters
HI My pilot is lit but when the hot water tap is used it doesn't ignite the system, infact it seems the gas jets are blocked, can you assist me please It was installed 11 years ago, is this old for a instant gas H W system?
    Champion:
  • 248 Answers
Gas valve or fan
Posted on Oct 12, 2009
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Pilot light lit but not igniting to heat water
pilot lit on gas furnace, but the burners won't light (Home ...
answers.angieslist.com > Home > HVAC
Oct 26, 2013 - i have a gas furnace with a lit pilot, but the burners won't light. ... if the thermocouple does not sense the heat of the pilot it prevents the gas controller fromturning on the burners. ... clamped onto the outgoing hot water pipe, if huydronic system) that is telling the furnace it is too hot, whether or not that is true.
Nov 18, 2015 | Water Water Heaters
Vaillant gas water heater - pilot light only, not lighting the main gas ring when tap is turned on..
first check to see if the thermocouple is close enough to the pilot. if it is and won't light the ring, replace the thermocouple.
Mar 01, 2014 | Water Heaters
Pilot doesn't stay lit
1) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Replace gas control valve.
Mar 02, 2013 | Rheem Water Heaters
Pilot l.ight will not stay lit
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Oct 20, 2010 | Whirlpool Water Heaters
I have a GE smart water heater model GG40T6A. the pilot light will not stay lit. what can i do?
Oct 08, 2010 | General Electric GE SmartWater Household...
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
Pilot light starts, but gas does not ignite.
IF no gas comes and the piolet is lit then the gas valve is stuck. You can purchase a seperate gas valve and replace it. If it is cost justified ,you will have to determine. As far as I know, one  cannot disassemble and repair the gas valve as you cannot purchase the parts for it.
Apr 04, 2009 | Water Heaters
I have no hot water, the pilot light is on help!
First try turning the knob all the way to "pilot" then turn it all the way to its hottest setting.
It sounds like the thermostat/sensor is stuck. This may jar it into working again.
Also look for any leakage or water around the burner.
You will probably have to replace the gas valve in the near future.
Also try tapping the side of the gas valve.
Jan 23, 2009 | General Electric GE SmartWater Household...
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
