The following Trojan Always gets activated whenever i reboot my windows xp PC - Fraud.VirusRemover2009 (SBI $8CE6B533) Settings HKEY_LOCAL_MACHINE/SOFTWARE/MICRIOSOFT/SECURITY CENTER/ANTIVIRUSDISABLENOTIFY (IS NOT) W=0 SPWARE = SPYBOT SEARCH AND DESTROY ANITVIRUS = SYMANTEC CORPORATE EDITION PLEASE HELP
  • 61 Answers
Http://www.malwarebytes.org/mbam.php
on the left is a link to the free version. Download it and run a quick scan.
Posted on Sep 25, 2009
Trojan virus promblem after open *** webside
Follow the given instructions to remove Trojan Virus from your PC.
1. Launch an antivirus program that you should have installed on your computer, such as Symantec's Norton or McAfee. Wait for the program's window to appear, then go to "Disk View." Highlight your computer, then select "Scan/Repair" so that the antivirus can detect the Trojan and trash it.
2. Exit the antivirus program on your Mac. Restart your computer again to ensure that the Trojan has been deleted. Empty the trash can on your computer once it is back up and running.
3. Disable the System Restore feature if you're a Windows user. Go to "Start" at the bottom of your screen, then right-click the "My Computer" icon to go to "Properties." Check "Turn off System Restore" under the System Restore tab in the "Properties" window, then select "Apply." Confirm that you want to disable System Restore by clicking "Yes" and "OK."
4. Update your virus definitions in your antivirus program. Open the program, or go to the website, to download the latest definitions so that you can receive the most recent alerts and keep your computer protected.
5. Scan your files to detect the Trojan file. Follow the instructions in your antivirus program to delete any suspicious files. You may want to write down the path and file name of the Trojan, which is usually found in the "C:\" hard drive. Then, edit your computer's backup registry by choosing "Start," then "Run." Type "regedit" in the window that appears and click "OK."
6. Search for the registry entry from which the Trojan derived, which may begin with "HKEY" followed by the file path. Delete the registry entry to ensure that the Trojan is removed. Exit the registry entry, and restart your computer so that the changes can take effect.
Dec 24, 2010 | Webroot AntiVirus with AntiSpyware &...
Tip
Update Windows XP Until 2019
If you desire to keep updating windows XP with new updates until 2019 there a new work around to that, simple create a new key entry like this Installed = dword 00000001 in the following registry path "HKEY LOCAL MACHINE - SYSTEM - WPA - PosReady" restart your machine and windows will start receiving the firsts new updates since April 2014. The trick is in making windows updates believe that you machine is running POS2009 that use XP Pro as base and is subject to updates until 2019.
on Jun 02, 2014 | Microsoft Windows XP Professional
Torjan remove virus
Reboot your computer if you have a Mac. Do this by holding down the "Shift" key while the computer restarts itself.
Hopefully, it may help to remove Trojan virus from your PC.
Dec 07, 2010 | Free of Virus Remove Fake Antivirus
I have virus av.exe and cannot remove it
This trojan runs as a rootkit, so you won't see it when it's running. It is a single file in C:\Users\username\AppData\Local (Vista), or C:\Documents and Settings\username\Local Settings\AppData (XP), It is marked as a system file, so you'll need to use the Folder Options in the control panel, to unhide hidden and system files and folders. As I said, with the rootkit loaded, you still won't see it there until you unload it. It runs by changing the registry so that any .exe run, will instead load the trojan. Attempts to run Internet Explorer or Mozilla Firefox will also instead run it. If you delete the file, or your antivirus finds it and deletes it, the changes to the registry will mean that from then on, whenever you try to run a program, you'll get a windows message asking you to select the file you want to use to open the .exe. (if this is the case, you'll need to use regedit in safe mode with command prompt, or rename regedit.exe to regedit.com).
To defeat the trojan, you must undo the registry changes, then reboot to reveal the file, then delete it. Here's how.
Run regedit. The trojan will load and give you all the fake warnings hassle. Do Ctrl-Alt_Del, and find the process 'av.exe'. End the process. Now in the registry editor, search for 'av.exe'. You should find a section HKEY_CLASSES_ROOT\.exe, where the (Default) REG_SZ has been set to 'secfile'. Edit this back to 'exefile'. Keep searching and you'll find HKEY_CLASSES_ROOT\secfile. Delete the whole secfile section. Keep searching - you'll find the odd line where it may be a recently 'searched for' item, where you can just delete the line, and you'll find it in a command line to run Internet Explorer. The full path to the trojan will be specified before the path to Internet Explorer. Edit this line to remove the path to the trojan, leaving just the path to Internet Explorer. A similar edit may be required for Mozilla Firefox. Find any other occurences of av.exe and deal with them in the same way.
Now, reboot the PC, and the trojan will not start up. Display system and hidden files, then go to the location of the trojan. Now you can see the little swine. Delete it, and empty the recycle bin.
Problem solved.
Enjoy!
Feb 07, 2010 | ASUS Eee PC 900 Notebook
I got a trojan virus,help
HELLO THERE:
PLEASE GO TO WWW.COUNTERSPY.COM AND DOWNLOAD IT THIS WORKS WONDERS FOR ME AND SEVERAL OTHERS I HAVE HELPED OK?
BEST REGARDS MICHAEL
Sep 15, 2009 | Apple Computers & Internet
Whenever i download and install any torrent file on my pc, i get a message to restart. when i restart the system, no icons will be displayed on the screen and not even the task manager gets operated. i get...
For task manager
1. Verity that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
"Task Manager".
1.1 "Local Group Policy"
a. Go to "Start" -> "Run" -> Write "Gpedit.msc" and press on "Enter" button.
b. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
c. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".If so set to other and viceversa
d. Close "Gpedit.msc" MMC.
e. Go to "Start" -> "Run" -> Write "gpupdate /force" and press on "Enter" button.
Note: If you are using Windows 2000, please follow KB q227302 instead stage "e".
Using SECEDIT to Force a Group Policy Refresh Immediately
http://support.microsoft.com/kb/q227302/
1.2 "Domain Group Policy"
a. Contact you local IT support team.
2. Verity correct registry settings::
a. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
Warning: Modifying your registry can cause serious problems that may require you to reinstall your operating system.
Always backup your files before doing this registry hack.
b. Navigate to the following registry keys and verity that following settings set to default:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system\]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"DisableCAD"=dword:00000000
c. Reboot the computer.
For no icons
go to run just type " explorer " and that should be it
Jun 06, 2009 | Microsoft Windows XP Professional
Disabled task manager
"Task Manager".
May 23, 2009 | Microsoft Windows XP Professional SP2
How to remove the virus Trojan.AVkiller in window XP profesional
Try running an online scan with the following site:
http://www.trendsecure.com/portal/en-US/tools/security_tools/housecall
Click on "Launch HouseCall"
Good Luck!
Dec 17, 2007 | Microsoft Windows XP Professional With...
Virus
Open Symantec.com and download Norton2007(Anti Virus) or u Can Try With E-Scan (Antivirus)
Gizmo1
Oct 18, 2007 | Microsoft Windows XP Professional for PC
Cannot start communications with the desktop computer
I have connected XP machine with Active Synch 3.1 to a wide range of E series Cassiopeias including E-15. The installation on XP is different from all previous versions of Windows. Without installing Active Synch you have to connect the switched on device to your PC & let XP find the device & install its own internal driver/service. Reboot the PC. Next install Active Synch - any version which should now find your device & start the service & establish your connection.
Sep 06, 2005 | Casio Cassiopeia E-15
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
