Question about Technics SA-DA8 Receiver
Sound just stopped all of a sudden .....unplugged it for 30 secs still did not work....fan was on but it felt a little hot on top
  • 832 Answers
Power amp output IC have an overheat. Cool it down and restart at
low volume. Send your e-mail if this did solve your problem.
Posted on Sep 25, 2009
Fan squeaks when on, what can I do
the bushes on the armature shaft are dry
there is a small felt pad around each bush and if you can get the motor then a few drops of machine oil on that felt will stop the noise.
May 27, 2015 | Dryers
Panasonic nnt553 top got hot smelt like bakelite burning then stopped working.
probably ur stirrer motor burn or temperature cut off tripping due to hi temp of ur cavity casuse by defective coling fan
Feb 21, 2015 | Panasonic Microwave Ovens
Computer fan turns on every 2 minutes and runs for 30 sec.
Does your computer seem to be running hot? If not maybe that's all the fan needs to run to do its job. The only thing you could try is to replace the fan.
Jan 04, 2014 | HP Computers & Internet
My Akira Pedestal Fan stopped working suddenly
the major problem with fans is the bronze bushes that the armature runs in get dry from use and seize on the shaft. IF you are capable get to the bushes and you may find a piece of felt next to the bushes . Put some machine oil into the felt and spin the fan with your finger until it loosens up. Otherwise scrap it
Dec 08, 2013 | Cars & Trucks
Compaq presario CQ40 is overheating within 30 minutes. Although cooling fan is working (fan sound is coming)
Laptop needs cleaning! Only experienced technician should open laptop, clean cooler and change thermal paste. This will solve the problem and save laptop from serious damage.
Jan 13, 2012 | Compaq Presario Notebook
My laptop was starting to run really high and hot and would shut down after just a few minutes. Last night when I tried to restart it, the lights all came on, but not the screen. It doesn't even sound...
Try to drain the static energy of the motherboard first by follwing this steps.
Take out the battery
Unplugged the power adapter
Press and hold the power button for 30 secs
Put the battery back in
Plugged in the power adapter
Turn ON the computer
If still NO display. You need to call HP tech support department for this could be a mainbaord issue. Since you mention that system is running hot. Computer fan might stop working that damages the mainboard.
Jun 13, 2010 | HP Pavilion DV6500T Notebook
My dryer whirlpool stopped in the middle of a
You have 2 problems.
1. a blown thermal fuse on the exhaust duct. It is white in color. About 1 and 1/2 inches long by 1/2 inch wide.It is on the back of the dryer. Unplug the dryer and remove the back panel.
2. Your exhaust system is blocked or clogged with lint.You must find and clear the blockage or you will blow the new fuse.
Jan 04, 2010 | Whirlpool Dryers
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
Technics SA-DA8 Receiver Logo
285 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
