Question about Cameras
No more live feed after it fell. - Cameras
Kenwood ddx373bt the red light flashes won't turn on. I pressed the reset button nothing works?
Check the 10 amp fuse on the rear of the radio. As its recieving a memory live power feed but not a ignition live feed hence the flashing red light. If the fuse isnt blown you need to then check the ignition live power feed cable as its probably open circuit did you use a wiring harness adaptor?
Apr 10, 2017 | Cars & Trucks
I have an aamco 4000 brake lathe, the disc feed is not working
The cross feed drive shaft is connected to the cross feed spindle via a coupling that resembles a universal joint that is threaded onto the end of the cross feed spindle. Either one of the roll pin holes in the drive shaft coupling has worn and the roll pin fell out or it has broken, or the coupling could have came un-screwed from the cross feed spindle. Remove the 4 bolts that hold the cross feed gearbox on and slowly pull it away from the machine and you should see the coupling I'm describing. My guess is that the roll pin broke or fell out due to wear. You can buy a new drive shaft and coupling or drill and install the next larger roll pin. Either way you should download a parts list for your machine. Just search for it, they can be downloaded free.
Aug 22, 2012 | Ammco Combination Disc/Drum Brake Lathe
Can I feed my snake live rats?
It is recommended that you only feed your reptiles pre-killed mice and rats. The reasons for this are:
  • if your live prey is more active than your reptile, he may not be able to catch it
  • there is a chance that your live prey can attack your reptile
  • if your reptile is attacked by its prey there is a large chance he may not want to feed on prey in the future, alive/dead
  • live prey can fight back during feeding, injuring your snake
Aug 14, 2012 | Reptile
Saturn Ion 2003 front defrost doesn't work on passenger side of vehicle. What can I do?
something must of fell down in there, or the hose that feeds that side fell off, check under dash
Jan 04, 2010 | 2003 Saturn ION
My hp laserjet 1320 fell off the desk and now will
check to make sure if the ink or your toner is install properly becoz it might fell of its correct position.
Oct 27, 2009 | HP LaserJet 1320 Printer
How do i store the radio stations on a sony cdx dab 6650 itune radio in hold the button mem is displayed radio plays alright switch of car and ilose the station when i swich back on thanks.
have you recently installed this unit...if so, it sounds like you have not connected the constant live feed wire......there are 2 live wires, one only activates when you switch on the ignition, this is called , a " switched live feed "...the other stays live when you swith off the ignition, this is the " constant feed live "...this feeds the memory while ignition is off.. check the connections, and i think you will find this is the problem....
Aug 13, 2009 | Car Audio & Video
My MP470 Pixma won't feed paper, it pulls right
Based on instructions from your website I pushed a letter sized piece of thin cardboard backwards through the paper feed rollers then shook the printer while holding it upside down. A Q tip fell out, problem solved.
Jul 19, 2009 | Canon PIXMA MP470 All-in-One Printer
Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Jan 02, 2009 | New Home Sewing Machines
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
