Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Hi I have an electrolux vacumm cleaner, super J model. My problem is that the powerhead only works if the switch is in the off position. vacumm motor works in the on position, opposite of each other. Can anyone help? Model 1401
  • 832 Answers
Looks like there's an interchanged wires in your vacuum. Both the motor and the powerhead must go together. Check it up. Leave the
motor wiring connection intact. Just tinker and check the powerhead
wiring connection .
Posted on Sep 25, 2009
Anyone needing parts? got 3 machines.
Posted on Jan 09, 2012
Hello, My Electrolux Oxygen motorized brush stopped working. How do I determine if it is the switch, a belt or something else that is causing the motor not to work?
Hey Lee,
We had the same problem and after taking it to a service guy who didn't even want to LOOK at the vacuum, it occurred to us to plug the powerhead brush directly into the handle and it worked! So, we were able to determine that the problem was the tube - not the brush.
We ordered a replacement tube.
Hope this helps.
Nov 06, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The powerhead brush died. The vacuum works just fine, but the brush doesn't.
there could be 2 reasons for this problem.
one) the powerhead is dead legit as in there is no power coming to it or the motor is actually dead.
2) something jammed in the brush and popped the reset button. The reset button is a red button located as your looking at the back of the powerhead on the right side. Usually a red square. Push it and it SHOULD start up again.
That being said, if you have done the reset button and it still does not work, that unit I beleive has either a 2 or 5 year warranty (cannot remember dont have the documentation in front of me) and if it is still covered under warranty for you, take it to your closest Vacuum repair shop. Do take the hose and powerhead with the cannister unit.
good luck
The powerhead stop working followed by the entire canister not working. There are no lights and nothing funtions.
this unit is made by eureka
just carrys eletrolux name
the original electrolux is now called aerus
Jul 12, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The clip that holds the EL5 powerhead to the wand has broken (again). How does one fix this?
i found this part online- search for part # via an exploded parts diagram of your specific unit (via google)
i ordered 5 of them because it always breaks or pops out.
this is a nice machine with crappy parts.
sorry :(
May 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
No power when its turned on
There was a (common cause) power arc during the swap (while running the vacuum).
The fuse located under the grey clipped-on plate of the canister is blown. The fuse is soldered-on the board and would need to be changed (board or fuse). Not "user friendly" zone. Warranty? Smart if they designed a breaker button instead of a fuse here...
Rick
Mar 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuum will not shut off
Sounds like you have wires crossed at the switch. The 2 wires coming in go to the center posts, 2 to the power head & 2 to the main motor.
Jan 31, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Powerhead no longer working
If you can hear the power nozzle motor running, but the belt doesn't spin, it is most likely the belt. You will have to get the belt from an Aerus dealer or a Vac shop. If you want to put the belt on yourself, you can. There or five or six screws on the bottom of the power nozzle that need to be removed and the cover should come off. Once the cover is off, you will see the belt and how to change it. Good Luck!!
Dec 15, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500 Powerhead Motor
Call an Aerus Electrolux dealer in your area.
Jan 29, 2008 | Electrolux Epic 6500 Vacuum
Parking position
I think it only works on the advertisements.
Nov 26, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
339 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
