Hitachi P42H401 42 in. Plasma HDTV Logo
Posted on Dec 16, 2007
Poor color i have my plasma for about 2 months and it seems recently there is little to no red colors on regular stations and hd stations dont look very clear either. i dont want to take to get repaired and look stupid because they say that is the way it is. i have tried to adjust the red all the way up and still it doesnt look right
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 24, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
52
Points
0
What kind of cables are you using? I had poor picture quality until I upgraded to HDMI, the picture's great now.
Bad picture on Samsung HP-R5052 50 in. Plasma HDTV
Hi there!
I suggest changing the screen , it is getting worn out
peace.
Very poor picture. Looks like some picture setting way off. LIttle red in picture.
If you are using component cables to hookup to the tv check to see if one has come loose on either end. This will cause the color to be off.
1helpful
2answers
Having trouble with the colors on my WIi, everything seems yellow and there is no red anywhere
I just wanted to add that I recently bought a WII and I have the exact same problem. I have a Samsung HD TV and I bought the additional HD cable that has the multiple jacks (i.e. green, blue etc.) I will post if I find a specific answer to the probem.
5helpful
2answers
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Maxent wierd colors
Artifacts can be seen on some screens that are trying to present high def color but cannot support the full dynamic color range. You will see this as banding or clustering in people's faces. Some brands handle this much better than others, and less expensive TVs can handle this rather poorly.
In your case, you may find that HD channels look worse than the regular signal channels.
Green hue on all inputs
Most likely there is a failure in the video processing. The flickering was from the failing components breaking down.
Your set can be serviced by an experienced tech who has spare boards and the facilities to service your set.
Jerry G.
1helpful
JVC HDTV Pictrure Distortion
Your TV needs to be calibrated. Rear projection TVs are very sensitive to movement. They have 3 color canons that need to be precisely aligned so that the colors overlay each other. They are like three projectors all aimed at the same screen.
If you were to enter the User Menu on the TV, you should find an alignment/calibration choice that will re-align the colors using some on-screen help.
If you are not able to resolve the situation on your own, a certified ISF Calibrationist should be called.
And, since you've bought this TV used, it should be cleaned by a professional (the canons, lenses, etc.)
2helpful
3answers
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Blue shading problem
2 months old? I'd call the dealer..it's under warentee. You have a problem that will not get better.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
