Question about Sharp Office Equipment & Supplies
My copier AR206 comes ON but display L then 6 continously
    Scholar:
  • 118 Answers
An L6-10 (if you hold down the start button the remaining portion of the fault will show up) fault means the polygon mirror in the laser unit has failed. Try shutting the unit down/unplugging it for 30+ seconds. If this does not reset the fault, you will need to have the laser unit (the LSU) replaced by a trained copier technician.
Posted on Oct 01, 2009
Di 350 running continously without screen displaying configuration, what is the problem?
Check the toner cartridge and check the imaging unit life.The IU life is 40.000 copies,after 40.000 need to change or refill.
Apr 16, 2013 | Minolta DiALTA Di350 Laser Printer
Trying to clean printer heads but numbers come up instead of letters to various heads in cleaning
Hi! There is an easiest way to clean up your printers head. Check on the right side of your printer.... there must be sign of setting (ie. sign of plier and brush).... 1. press that button and watch the printer LCD display.. 2. Press contineously until it display (u) small one.. not (U). 3. After display u press black or color button.... your printer will start cleaning works and it print one page. 4. After completing, take the paper and put into your printer scanner... and press black/color button.
That is the way to clean up your printers head.... good luck
Sep 08, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Continous boot cycle
Press and hold # and 6 from the front panel keypad while plugging in the power cord.
For products that do not have # and 6, press Cancel and the Right Arrow.
Continue holding both buttons until the reset displays, and then release.
Select the language and country/region if prompted.
Note: Resetting the unit will erase some stored data. Most of this data will be restored when the all-in-one re-establishes communication with the computer.
If this does not solve the issue it will need to be sent in for servicing or just buy a new one.
Jan 01, 2010 | HP Photosmart 2575 All-In-One InkJet...
Printing problems
Try this, Get to your printer menu, then settings, see if you have a choice of restoring to factory defaults.It may solve your issue,it can't hurt.Also did you use the manufacture's ink cartridge? Many printers won't recongnise other ink cartridges.Good Luck.
Sep 19, 2009 | Office Equipment & Supplies
My machine starts as soon as it gets stop continously
Do you get a Error Code on the display... If so, what is the code... It should start with a "E". If you want our Help you have to give up more info..
Jul 05, 2009 | Canon NP 6050 Copier
ERROR H5-01
H5-01 means that you have 5 continous paper jamm in the machine. Try to rest by pressing C INTERUPT 0 INTERUPT 14 START.
If problem still occur, check the paper detection sensor by pressing C INTERUPT 0 INTERUPT 30 START 1 START. and manually activate the sensors and look at the display.
May 27, 2009 | Sharp SF 2540 Copier
Error message E 7
Try these steps to cancel the error, press the buttons continously
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not, do again step 1 until the display turns off.
STEP3.press 14 then press print button
Jan 29, 2009 | Sharp AL 800 Copier
Continous beep every 6 seconds
There is either a problem with your memory or your BIOS settings. Did you recently change any settings in your BIOS? If so try resetting it. You may refer to the motherboard user Guide for help regarding resetting your BIOS/CMOS settings. If you cant find it you may also try to remove the CMOS battery on your motherboard for a few hours and then connect it back this should have reset your BIOS.
If you are sure you havent changed any settings then there may be a problem with your RAM or the slot in which the RAM is connected. Check it by using a spare slot on your comp. If it does nt work then you may have to replace your system RAM.
Oct 27, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Canon BJC-70 color bubble jet printer
the pickup roller needs cleaning- canon have a special device for cleaning this - its an MG-10-hope this helps
Aug 29, 2007 | Office Equipment & Supplies
106 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
