Question about Samsung SyncMaster 753S 17" CRT Monitor
My monitor is switch off turn on - Samsung SyncMaster 753S 17" CRT Monitor
  • 438 Answers
Problem in on off circuit...change it
Posted on Sep 25, 2009
Problem in Samtron 45Bn Monitor
Try connecting the monitor to the mains instead of the UPS.
If it works OK then the problem maybe the UPS and that it is very close to the max output of the UPS.
If not then the monitor is faulty.
Mar 12, 2013 | Computers & Internet
Problem with monitor
Since the monitor is working normally other than turn off, I suggest plugging it into a power bar with switch. The pad switch is probably defective in the monitor.
Mar 11, 2012 | Dell Computers & Internet
My AOpen 19" LCD Flat Screen Monitor (Model F2915) is like new and works perfectly except for one thing. The push button power switch located on the top of the monitor has broken off and fallen insid
Certainly, if you jumper the connections to see which ones turn the monitor on or off, then you can go to an electrical supply place and get a micro switch and wire it in in place of the power button, or perhaps find a type that is flat that the power button can press. What you need to determine is if it is a push-on, push -off type switch, which always stays on or off depending on position or if it is a momentary interrupt switch where the button pressed momentarily turns it on and then releases and a second press connects the circuit to turn it off. You can do this by testing with your jumper wire, attach it and if the monitor stays on when you remove it, then goes off when you attach it again, you need the second type switch, if it goes off when removed, you need the always-on always -off first type switch. .
Mar 07, 2012 | AOpen F90GS 19 inch Monitor
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
Monitor is switching off immediately after system is switched on. Again when monitor is switched on, images appear for about 3 seconds and again monitor switches off.pl give the solution.
You need to determine if you is turning off or going into standby mode. When your monitor shuts off, the power light will turn orange if it is in standby or the light will turn completely off if the monitor turns off. If your monitor goes to standby, that means that your monitor is losing signal which indicates a problem with your PC. #1 Make sure cable is firmly secured and both screws are tight #2 Check your video card make sure that it is firmly in its slot. Take it out and put it back in. *as long as your computer is open give it a good cleaning with compressed air* If those things check out it is possible that your video card has failed and needs to be replaced.
If your monitor is powering off #1Check plugins- try something else (i.e. lamp) in the outlet #2 Try your PC's power cord in your monitor
Oct 21, 2010 | ViewSonic Computers & Internet
It wont power up bro
It is possible that your monitor is on a GFI switch. These switches turn off if they detect a problem that could incur a shock, or if they are getting worn. Check if there is a power outlet in the same room with a red and black switch. If so, push the reset switch, typically the red one.
Your monitor may also be on a switch activated outlet. Is it plugged into the top outlet? See if a wall switch nearby controls the outlet. then try turning on your monitor.
Is the surge protector your monitor is plugged into turned on?
Check the cord on the back of your monitor. It is possible it may be loose. Plug it in all the way.
Some Viewsonic monitors have a power pack that is not inside the monitor case. Check the wiring between it and the wall and between the pack and the monitor for frays.
May 12, 2010 | Computers & Internet
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
Samsung SyncMaster 753S 17" CRT Monitor Logo
61 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
