Question about HP LaserJet 4250n Printer
Waititng for tray 2 to lift - HP LaserJet 4250n Printer
    Scholar:
  • 96 Answers
If the tray doesn't lift than there may be a problem with the lifting motor. remove the right cover assembly and near the center bottom is the motor assembly. insert the tray and check to see if the motor is functioning. also check the tray, there is a gear on the tray that drive the tray up into position.
Posted on Sep 25, 2009
Please how do i resolve 60.02 hp printer error
Something is preventing tray 2 to be lifted.
Take tray tray out of the printer and check for obstructions preventing lifting of the paper.
Switching tray's is possible to ascertain if the problem lies with the tray or the printer.
If the problem is with the printer the lift motor is suspected to defect.
Dec 31, 2010 | HP LaserJet 9050n Printer
Our printer is showing a malfunction error code of C0204....any suggestions?
Tray 2 elevator failure. Something is wrong with the paper lifting in tray 2. Most common cause is improperly loaded paper in the tray so I would check that first. If you can't find any issues with tray 2 then you can leave it open an inch or two and reset the code so you can still use the copier. Then have a tech look at the tray as you could have a lift motor or lift sensor going bad.
Good Luck and Thank You for using Fixya.
Nov 18, 2010 | Minolta bizhub 200 All-In-One Printer
I have a WorkCentre 5225 and it is telling me that I have an error (code #071-210) what is this error?
That error specifies a Tray 1 lift failure.
You probably can hear the motor lift 127K38171 when you re-insert the tray, so maybe the lift motor is bad or maybe a sensor
930W00113 is falsely accusing our motor.
Whit
Item, Inc
Aug 13, 2010 | Xerox Workcentre 5225 / Copier, With...
Error c-0910
C-0910
The Lift-up Sensor is not blocked even after the lapse
of a given period of time after the lifting motion has
been started.
Basically your paper tray 2 did not lift right. Open the tray and make sure the paper is loaded correctly. The paper should be touched on all four sides by the tray or by adjustable guides. Open and close the front door with the tray out. Once the machine is ready to copy close the drawer you should hear a slight buzzing sound as the tray rises. If you don't or you hear a banging or grinding sound the tray lift motor may be damaged and you will need to call a service technician.
If the code keeps coming back pull out tray 2, open and close the front door to reset and leave the tray 2 partially pulled out until a technician can repair.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How to clear Malfunction code C-0204
C-0204 The Lift-up Sensor is not blocked even after the
lapse of a given period of time after the lifting
motion has been started.
Apr 08, 2010 | Konica Minolta bizhub C351 All-In-One...
My numark cd mix 2 keeps shutting off at the power supply.
I had the same problem and sent it in for repair. they said it worked fine for them, but they had their own power supply. instrumental parts dot com sells power supplies but the last time i ordered they were 2 months waititng.
Dec 10, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Nov 25, 2009 | HP LaserJet 8150n Printer
Error 416 hw
The Tray Table in Tray 2 took more than 40 seconds to rise or didnt rise at all. First, check the tray 2 lift gears. Second check the tray 2 lift arm. Third check the tray 2 table height motor (M403). Lastly, check the tray 2 Height Sensor (S413)
I have listed these in the order of their likely to fail. Most of the times, its the lift gears
Jun 24, 2009 | IBM Infoprint 70 Laser Printer
Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Sep 25, 2008 | Ricoh Aficio 450 Copier
HP Laser Jet 4350tn issue
open tray 2 and tray 3 and try it.
Dec 03, 2007 | HP LaserJet 4350TN Printer
HP LaserJet 4250n Printer Logo
179 people viewed this question
Seeker5211
Seeker5211
