Question about Microsoft Presenter 3000 Mouse
My presenter Microsoft 3000 was working perfecly
My presenter Microsoft 3000 was working perfectly and suddenly not. I change batteries but nothing happen. I need the manual
Posted on Nov 04, 2009
My 2001 Kia optima will not accelerate over 3000 rpm
I had that exact problem with my 2005 Kia optima.. It suddenly started one morning.. My Kia would not turn over.. I felt it was a power issue so I unattached my after market fog-lights that I have attached to my battery.. That got my ride to start, but upon driving it refused to go past 3000 rpms (in all gears)... I took apart my battery terminals and scrubbed them down with a tooth brush and coca-cola.. That was a perfect fix for my situation.. My Kia ran perfectly right after...
Good luck
Sep 21, 2012 | 2001 Kia Optima
I bought a microsoft arc mouse, wireless, with a USB transmitter, just a month ago and it was working perfectly, then suddenly and i mean SUDDENLY, stopped working, no reason it just happened, the light...
Hello, have you tried changing the batteries in your mouse? They are probably dead or dying and that is why it is not working. Also, try restarting the computer. If you cannot even use a regular wired usb mouse, there may be something going on. Try changing the batteries, restarting the computer, and using a regular usb and a regular PS/2 mouse.
Thanks for using FixYa!
Jul 24, 2011 | Microsoft ARC Mouse
How do i downgrade psp 3000 running ofw 6.31....help me please
Unfortunately there is nothing you can do at present to downgrade a PSP 3000 that has firmware above 5.03. Pandora battery does not work and neither does chickhen, until someone works out a way of enabling custom firmware on a PSP 3000 above 5.03 I am afraid you are stuck to official firmware.
Hope this helps and thank you for using FixYa
Sep 20, 2010 | Sony PlayStation Portable (PSP) Console
Mouse Problem- Not Working
i should reinstal his driver just to make sure is working properly,you can check in start-my computer-rightclick manage -device manager- usb then click on action button and Scan for hardware changes.
Dec 10, 2009 | Microsoft Comfort Optical Mouse 3000...
Microsoft Notebook optical mouse 3000 not working
Have you tried changing the port in which the USB wireless receiver is plugged?
Or is the receiver internal to the notebook?
If the receiver is internal, try updating the drivers for your machine by navigating to the manufacturer's support site.
If you plug a wired mouse into the machine what happens? If you get the same result, it may indicate a problem with the USB settings on your machine. I would, again, suggest updating the drivers for your machine.
If that's the case, try plugging another USB device into the machine and see if it works properly.
If none of those options provide results, I recommend you return the mouse for a refund or a replacement, especially if you have the receipt.
I hope I was able to help you. Good luck!
Aug 08, 2009 | Microsoft Wireless Notebook Optical Mouse...
Wireless Mobile Mouse 3000 not working
I suggest you do the following. After having synchronized both connecting buttons in mouse and receiver, take off battery and next look for a tiny thin button that protrudes from one of the sides where the receiver is placed in mouse, hold it depressed and put back a new and fresh battery releasing simultaneously this button. Mouse would work correctly. Good luck!!! Chawah.
Aug 03, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse works perfecly well for couple of minutes then stops.
try a new batteries most likely it is the batteries and sorry to hear about this issue
Apr 15, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Presenter 3000 does not work
My 3000 has a green light but it only flashes to indicate the sync period during which time you should press the button on the back of the presenter. The presenter works well and to date I have had no problems.
Nov 02, 2007 | Microsoft Presenter 3000 Mouse
Won't advance slides
IF IT JUST DOESN'T WORK... (But the laser pointer is still working when in 'presentation' mode) You need to 'Sync' the presenter and the reciever... as follows: Turn the presenter on, and turn it over so you're looking at the back of it. See the button in the middle? Press that button, and the button on the USB reciever stick, simultaneously, while holding the two of them quite close together. Problem should be solved. If you turn it on and the display isn't working, or if the laser pointer doesn't work when in 'presentation' mode, you need to change the batteries. I thought I had a dud unit until I found out about the 'Sync' function!!! Definitely on the 'need to add to documentation' list!
Aug 21, 2007 | Microsoft Presenter 3000 Mouse
Wireless presenter dont work
Did you press the right button on the remote? To 'sync' the sender and reciever, and thus start it working, you've got to turn the handheld OVER and press the mysterious little button in the middle at the same time as the button on the USB stick. Also helps if you have them right next to each other when you do this. You should see a green light on the USB stick, and the laser pointer should work on the handpiece if the batteries are good. Mine was working fine for heaps of presentations then suddenly stopped one day and only the laser pointer would work. Batteries were fine, as is the common story. Then I found out that if you turn the presenter over and press the 'reset' button in the middle simultaneously with the USB reciever stick, the two 'sync' and it starts working again, hey presto. I've always found it a breeze to use once I figured this out. If that doesn't work take it back, you need a new one.
Jun 29, 2007 | Microsoft Presenter 3000 Mouse
Microsoft Presenter 3000 Mouse Logo
741 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
