Question about Dirt Devil KONE Hand Vacuum MO213BLU Vacuum
Dirt devil kone won't hold a charge. Its constantly on the charger but yet won't hold a charge long enough to do anything
SOURCE: dirt devil vibe 088915v
Are you talking about the beater bar? If so, you probably have a broken belt
Posted on Jan 16, 2009
  • 126 Answers
SOURCE: Dirt Devil Repair
Any warranty dealer for Dirt Devil should be able to supply a schematic for that machine. They have access to the dealer web site and can download the information.
Posted on Feb 02, 2008
  • 294 Answers
SOURCE: how do i open my
remove vac from charging base. twist the two section apart. it will turn about 1 inch and then pull apart. this will expose the filter to remove to empty the dirt. reassemble in reverse.
Posted on Jan 21, 2009
SOURCE: how do i open my dirt devil kone to empty it?
Grab the upper and lower conic sections, one in each hand. Twist the lower section clockwise to remove from the upper section. The filter is in the section - remove and empty, then replace and twist back to close and lock.
Posted on Jul 14, 2009
SOURCE: dirt devil en vision
Locate model no. at the rear bottom of the vacuum.
Then go to Dirt Devil site: http://www.dirtdevil.com/CustomerService/Manuals/
(this site will not find the manual under the name, just model #).
Posted on Nov 18, 2009
Try to change the battery packed
It may not be the battery it may be the charger. either way it will cost you about as much and the unit did new.
Jan 25, 2014 | Vacuums
My Dirt Devil KONE Hand Vacuum won't unscrew to empty
sounds like it may be cross threaded , or bits of grit holding it tight ,try tapping round the rim with screwdriver handle to see if it will loosen anything that's holding it ,then get someone else to help you hold one end and you hold the other end and twist..
Mar 11, 2013 | Dirt Devil KONE Hand Vacuum MO213BLU...
Hello I Have a Dirt DEVIL KONE Champagne in Color. Not the Kurve But the KONE. It was Working Fine The other day, But Is now NOT Powering On When I Try to Turn The Switch on at the Top. The Indicator...
Hi Ross, sorry for this delay, but the email does not seem to be working, I will get on this as soon as I can and will efinatly have something for you shortly, been one of those days and I am not catching up yet.
Dec 07, 2011 | Dirt Devil Kone Vacuum- Blue Vacuum
Hi, I have a Dirt Devil Cone vacuum and my daughter's dog chewed through the charger cord. Unfortunately, she threw away the charger part. I am looking to replace the cord and/or charger plug if that is...
Information on your Dirt Devil Kone M0213BLU can be found here:
http://www.dirtdevil.com/products/details.aspx?id=M0213BLU#parts
A link is available to download the manual and to find replacement parts. If the part you require is not listed suggest you contact the company through their website:
https://www.dirtdevil.com/contact.aspx
Apr 11, 2011 | Dirt Devil KONE Hand Vacuum MO213BLU...
It doesn't hold a charge. After just a few seconds of running, the motor starts to drag.
Either the Charger is not putting out enough charge or the battery is bad.
If you don't have a voltmeter to test the charger take it to a local auto parts store or mechanic and they will probably check it for free.
Dirtdevil.com is the source for either the battery or charger.
Nov 20, 2010 | Dirt Devil Kone M0212 Bagless Handheld...
The battery won't hold a charge, is there a fix or is it replaceable?
Well first of all you may check that the charger (adapter) is working or not, you may use a volt meter to check it out or use another charger to make sure....... further you may follow the step below -
1. Remove the battery pack from Vacuum.
2. Hold down the power button for five seconds.
3. Reinstall the battery to reset the system.
4. Plug the Charger directly into vacuum.
5. Charge the battery untill the power light is solid green again and keep the vacuum on the charger for an additional 72 hours (3 days). Important: Do NOT interrupt this charging cycle.
If further you have the same problem it means it's time to change the old battery with new one.
Good Luck!!
Thanks for using FixYa!!
Oct 13, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Light goes on my kone but it won't work
Good Luck!!
May 19, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
How do i open my dirt devil kone to empty it?
Jan 21, 2009 | Dirt Devil KONE Hand Vacuum MO213BLU...
I can't get the charging light to turn on.
I have the same problem, after our building had a electricity problem. The electricity spiked when the utility company came to fix a problem. Several adapters in our apartment seem to be affected. Like my Kone, my dirt devil detailer had the same problem: charging light didn't come on, and while it charges, it only gets up to weak power. I got a new charger/adapter and when I plugged it into the base, the charging light was working again.
Jun 24, 2008 | Dirt Devil KONE Hand Vacuum MO213BLU...
Dirt Devil KONE Hand Vacuum MO213BLU Vacuum Logo
338 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
