Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Float problem with Hoover Steam Vac Deluxe
I can hardly go 2 or 3 feet before the float pops up and I have to turn the unit off to reset the float. I have had problems with this from day one but I used to be able to go further. The float pops up all the time. I thought it was from bumping the wall or furniture but now no matter how slow I go it happens all the time. Do you have a solution?
  • iris727 Feb 16, 2008
    I have this problem AND there is NO suction. I can't seem to get the suction to start. I empty the tank, reposition everything and still NO suction. What can I do?
    President:
  • 1,673 Answers
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Posted on Jan 10, 2008
Hoover carpet cleaner f5915905 the handle release won't lock. what should I do ?
Repairing the Hoover Steam Vac Deluxe - YouTube
? 6:01
https://www.youtube.com/watch?v=QBtWcC4gqjY
Apr 21, 2009 - Uploaded by general0ne
I think Ill make one for the Dual V steam cleaner and provide some tips on maintenance. Good job ... The ...Missing: lock
Dismantling the Hoover Steam Vac Deluxe - YouTube
? 6:16
https://www.youtube.com/watch?v=sul52ULCR90
Jan 12, 2010 - Uploaded by general0ne
Dismantling the Hoover Steam Vac Deluxe. general0ne .... Aftercleaning the screen as shown on the video ...Missing: f5915905 ‎lock
Nov 29, 2015 | Hoover Vacuums
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
The brushes on my steam vac won't spin
I used the suggestions found from a previous question found on your site.. thanks though. will recommend your site to all.
Aug 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
I only used it once or twice and then the suction stopped and I can't figure out what went wrong. Hoover Steam Vac
This model has suction as soon as you turn on the machine. make sure the lower tank lid is on properly and the tank is latched in place. check the hose attachment door if that may be open. There is a float in the tank that will stop suction whenit is time to change the water, make sure the tank is empty.
Aug 06, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover steamvac not picking up water
you don't have the recovery tank lid on correctly.
Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Loss of suction
Make sure the recovery tank lid is on correctly. Also make sure the float on the receovery tank lid is down.
May 24, 2009 | Hoover F7431-900 SteamVac Vacuum
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac
The foam filter is up too high, it is on the bottom side of the lid. Leave about a 1/4 in gap, then it should work ok again.
Mar 01, 2008 | Hoover F5906-900 Upright Steam Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
312 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
