Question about Hotpoint WMM39 Front Load Washer
My hotpoint wmm39 aquarius extra washes but does not spin
The washing machine washes but does not spin at all - no attempt is made to spin, it just finishes its cycle
  • 909 Answers
You are in an unfortunate delemer. It is either your spin winding thats gone or the control board or timer thats faulty. Normally a technician has spares to test against to prove by process of elimination.Aquick test, pull the pressure switch pipe off the drum assy. and retry spin cycle. Alao take note if all water is drained out of the tub. Let me know
Posted on Sep 25, 2009
After a wash the water is not emptying out of the we64 aquariouse extra, hotpoint. how do i fix this? thank you
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 17, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Wont spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 09, 2010 | Hotpoint WMM39 Front Load Washer
Drum has stopped moving
Hello, these is usually the drive belt,the drive belt is the easiest parts to replace.
Thanks
Jun 10, 2010 | Hotpoint WMM39 Front Load Washer
Hotpoint washer
common problems with timer which work like a clock and goes though the cycle, bad timer will cause it not to go through its cycle. it very cheap and easy to replace everything is all plug in.
Nov 14, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint wmm39 contol panel
The instruction book below has a picture of the control panel on page 17,from the off position turning clockwise the control dial is lettered position 1 = A, 2 = B etc http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HBWMA48.pdf
Jun 11, 2009 | Hotpoint WMM39 Front Load Washer
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint WMM39 Front Load Washer Logo
148 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
