Question about Palm TX Handheld
Problems with screen of my tx. I will write a letter and it quickly gives me a different one. It is as if the screen is "jumpy" and wants to interpret an instruction before it is really made... Calibration is often off center, and I have to guess where to touch to get the desired letter or sign...
  • rhainesco Sep 25, 2009
    I have of course tried that many many many times. It doesn't help at all.... Thanks anyway. Is there anything else to try??? I hear this is a very common problem. True?
  • Palm Master
  • 4,338 Answers
Go to applications>prefs> touchscreen and calibrate the screen there.
Posted on Sep 25, 2009
  • JDTec
    JDTec Sep 25, 2009
    you can try hard resetting the unit.
2004 Kia rio. Takes a long time to turn over. Jumpy when driving, sometimes runs rough when idling. Check engine light is now on... What could be wrong?
16v engine ? anything and everything could be wrong firstly check the plug gaps 25th ,then see how it starts and runs ,then failing which check any vacumn pipes for fracture and perished ends .Then start the big things like fuel pressure and sensors as it could be cumulation of different things like the plugs causing the starting problems and the O2 sensors causing the rough idle .Sorry no quick solution here but a process of elimination using a bit of knowledge and a multimeter to test the sensors
Dec 31, 2012 | Cars & Trucks
The tv i own: Panasonic TX-32LX77 LCD Monitor (TX32LX77) . i want to know if this is HD. if i hook up the tatasky HD box, will i get a full HD output? thnx
The TX-32LX77 is an HD TV but only has 720p (1366 x 768) resolution. Full HD is 1080p. (SD is 480i.)
I wish that I had better news.
(It's possible that you won't notice the resolution difference; small screens don't always need the full 1080 lines of pixels from top to bottom of the screen to give a crisp picture.)
May 23, 2011 | Panasonic Viera TX-32LX77 LCD TV
I want to buy a Panasonic 32" model. I am
Those are just idenification numbers of the product and the demintion and the lenght and with of the product.
Feb 14, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
I cannot get the setup menu to show on the tv. Everything else is working fine.
I am not entirely clear on your situation because I don't know what type of cables you are using with this new receiver.
In other words, if you are connecting a TV that has HDMI inputs, (flat wide connectors) then you should connect it to the OUTPUT HDMI connector on the back of the receiver. (See the quick setup link below on page 2.
The new inexpensive HDMI cables have a lot of defective units, so cross check with other HDMI cables if you have problems.
If you are using conventional cables because the TV doesn't have HDMI I would connect the yellow cable output labeled "MONITOR" on the back of the receiver to the Yellow input (video 1, or line 1) INPUT on the back of the TV. Then set the TV to Video 1. Then you should get a display of the Setup screen.
Make certain that you push the "setup" button on the front of the receiver.
Below I've put in some links for either the very quick setup and the full manual.
I hope this helps,
Best Regards,
Mark
Quick Setup Manual Link
http://filedepot.onkyousa.com/Files/own_manuals/TX-SR606_QSS_En_Rev1.pdf?CFID=1396296&CFTOKEN=48521992&jsessionid=f030bbb9c220b0213d40674b2430783b5228
Full Manual Link
http://filedepot.onkyousa.com/Files/own_manuals/TX-SR606_En_A_Rev1.pdf?CFID=1396296&CFTOKEN=48521992&jsessionid=f030bbb9c220b0213d40674b2430783b5228
Jan 26, 2011 | Onkyo TX-SR606 Receiver
I am having problems with my Palm TX touchscreen, I touch one letter and another one moves
HI,
I am sending you a link to a Palm support page. There is a feature that allows you to do a live chat with a Palm technician. You have to try the options and then I believe the chat feature will show up. Let me know if you need further assistance. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/home/page_en.html
Aug 15, 2009 | Palm TX Handheld
When pressing certain digits or letters on keyboard different letters appear on screen?
unfortunately this is a common problem in some compaq laptops.
Ypu will need to replace your Kb or clear your cmos/bios memory to see if debuggin your memory still works fine.
Locate your cmos/bios battery disconnect for a while, turn on your laptop and verify that your cmos memory was reset, reconnect your battery and set your dates, this will resolve your kb issues.
If you still have problems we can replace Kb for 49 usd
10001 buckwood ave 79925 El Paso Tx.
Contac us if you are interested
Thanks, please leave feedback
Vcrtech
support@vcrtech
vcrtech@hotmail.com
www.vcrtech.com
Apr 28, 2009 | HP Compaq Presario R4000 Notebook
My Compaq Presario SR1010NX is freaking out. The screen lettering streaks and gets jumpy. I need to find out if its the CPU or the monitor. I feel the CPR needs some sort of upgrading or replacement part...
If you want to test the monitor. plug it into another computer. Most likely its the video card on the computer and not the CPU. CPU's dont give you lettering streaks. Also try plugging your computer into a different monitor. If it is still streaking then it definitely is the video card and in that case just replace the video card.
Mar 23, 2009 | Compaq Presario SR1010NX (DW254A#ABA) PC...
Jumpy when accelerates
its prob not getting enough fuel, change the fuel filter and if that doesnt work give it a tune up
Mar 21, 2009 | 1991 Cadillac DeVille
When i try to type in address the wrong letters keeps coming up
Do a screen calibration. There are different ways to get to it depending on which GPS you have but that usually fixes problems like that.
Jan 21, 2009 | Garmin Touch Screen GPS Receiver
I/O device error
My MuVO TX was having problems until I installed the latest firmware. The last firmware release was in March 2007. If you haven't updated the player's firmware since then, try downloading it and installing Creative MuVo TX FM Firmware 1.24.02.
If you can't get your computer to even recognize the player anymore, you could try reinstalling the Creative Mass Storage Driver 1.07.00.250.
Oct 10, 2007 | Creative Labs Nomad MuVo TX MP3 Player
Palm TX Handheld Logo
53 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
