Question about Music
Hi, I have a Gibson les paul guitar and when i select one of the pick ups i lose all sound from the amp. If i select both pickups then everything is fine as is if i select the other pickup on its own. The fault does not happen every time but is intermittent. What could the problem be?
  • Music Master
  • 5,603 Answers
It is likely dirty switch contacts on the selector switch. Get a can of CRC226 at home depot and spray the contacts sparingly. The CRC226 is in the electrical department of HD, usually near the electrical tapes in a small blue can.
Posted on Sep 25, 2009
Testimonial: "Thanks will try this weekend"
    Novelist:
  • 133 Answers
One possible cause is a dirty contact on the switch that controls which pickup is active - you would need to clean the contacts or replace the switch if the cleaning is impossible.
Another possibility is a broken wire somewhere beetween the pickup selector switch and the pickup that doesn't work - this would have to be resoldered.
If the pickups have separate volume and/or tone controls then it is ok to check those too, there may be a broken wire to / from the volume potentiometer or some damage or dirt in the potentiometer itself - again, broken wires would need to be resoldered or replaced, the potentiometer can probably be cleaned, but if it is damaged then it is probably best to replace it.
Hope this helps somewhat.
regards
Triarcuate
Posted on Sep 29, 2009
Guitar serial number lookup
Try and find similar on to as a guide.
Jul 28, 2014 | Gibson Les Paul Studio Electric Guitar
Ephiphone guitar pickup wiring
Or a bad solder connection on the ground wire on the jack, or shell/sheild on the guitar.
Here is the list you seek.
http://www.gibson.com/en-us/Support/TechSupport/Wiring Diagrams/
Feb 03, 2012 | Epiphone Les Paul Studio Electric Guitar
I need documentation to set neck adjustment and intonation for a Gibson ES-359 custom. It doesn't seem that Gibson has anything readily available.
Intonation is easy if you have an electronic tuner, and instructions for a Les Paul style guitar will be close enough. Same with neck adjustment, if it is a set neck, use the Les Paul info. If a bolt on neck, everything but the neck angle is still relevant.
Jul 01, 2011 | Gibson Guitar Gibson Custom ES 359 Semi...
I have a Boss GT -10 and its great. When I plug in my Gibson les paul into it and play it, there is sound. When I plug in my Other les paul with emgs in it, no sound comes out. I plugged them both into...
The half-way cord is the clue. Read up on unbalanced and balanced lines and TRS connectors.
One of these requires TRS connections and the signal is being carried on the RING of the TIP-RING-SLEEVE connector. Plugging in half-way the TIP touches the ring pickup contact. The emgs one MAY use TRS type cables and there may be a reason the signal and hot of these are reversed. If I could find schematics on all this equipment I could unravel the exact cause. You could make an adapter with a Stereo 1/4 inch plug and a 1/4 inch jack by wiring it to swap the tip and ring between them to use for connecting to the emgs guitar. ALSO verify you are using the SAME type guitar cable for both.OFTEN a TRS cable will NOT turn on the electronics when plugged into a guitar. Use an unbalanced instrument cable unless you have the XLR type output. Use of an adapter from the XLR type cable into the Boss will usually not work.
Apr 24, 2011 | Roland Boss Gt-10 Guitar Effects Processor...
Well i dont have a les paul studio i have a les paul menace with the same problem. Hopefully you can still help me. When i plug the guitar in and turn the volume up on the guitar a loud hum appears. ...
OK... Most of the guitars have a PAINTED on shielding in the well with the electronics. Sometimes the electrical connection to this is broken causing hum. Sometimes the connection is by way of the potentiometer shaft nuts and they spin and break the connection. This paint is conductive and often black know as aquadag. Use an ohmeter to verify connection.
Oct 27, 2010 | Gibson Les Paul Studio Electric Guitar
I have just purchased a les paul ultra 2. The nano pick up does not work without increasing the gain. I thought the volume control on the front controlled the nano pick up and the gain was for just that. I...
You need to adjust the controls for the nano on the control cavity plate on the back of the guitar the way you want them first. Here is a link to a simplified explanation:http://www2.gibson.com/Products/Electric-Guitars/Les-Paul/Epiphone/Les-Paul-Standard-Ultra-II.aspx A better explanation should be in the manual but I don't think they did as good of a job as they should have.
Oct 17, 2010 | Epiphone Les Paul 100 Electric Guitar
Low volume on front pickup of Epiphone Les Paul
i have an old sg, and this happened to me too. the repair guy told me that inside the p/u, the windings were broken, resulting in a lower output. go on e-bay, and look up a neck pos. humbucker. there everywhere. or do yourself a favor, and do what i did. i have an epi. flying v, and epi. les paul. on e-bay, i bought gibson 57 classics. i put these in both my guitars, and i now have great sounding guitars. you will not belive the difference. good luck, scott
Jan 31, 2009 | Epiphone Les Paul Studio Electric Guitar
Old yamaha electric guitar
Santana's had quite a few guitars, take your pick:
1972 - Gibson Les Paul / Gibson SG Special with Humbuckers / Gibson L-6S
1975 - Gibson SG Special with P90 pickup (Woodstock Festival)
1976 - Yamaha SG 175B / Gibson SG Special with 3 Open Coils
1982 - Paul Reed Smith (PRS) Custom
1988 - PRS Santana II with PRS Santana III nickel-plated pickups and .009-.042 D'Addario strings
Nov 10, 2008 | Yamaha Electric Guitar
Music Logo
100 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
